mos Posted May 3, 2003 Share Posted May 3, 2003 Hi all, my supra N/A didnt come with the drop down front spoiler and i am wondering if this would help to explain the reason why at non legal speeds on the twisties (private road of course) The front of my car seems light. I have done the power steering mod so am at standard pps setting. This is getting me down a bit as i just dont have the confident feeling to throw it into the corner. It almost feels like i turn the wheel and the car thinks about it and even then isnt quite so sure. On another note has anybody ran lance's settings from mkiv.com and how did you find them on U.K. roads. Link to comment Share on other sites More sharing options...
THOR Racing Posted May 3, 2003 Share Posted May 3, 2003 Do you have your engine under tray still in tact? Removal of this under tray can seriously effect the high speed stability of the Supra. Regards Pete Link to comment Share on other sites More sharing options...
mos Posted May 3, 2003 Author Share Posted May 3, 2003 Yes still intact, The only difference i can think of is my indicators are not in my front scoops anymore Link to comment Share on other sites More sharing options...
Terminator Posted May 3, 2003 Share Posted May 3, 2003 Has the car been lowered? Have you had the geometry checked? Any excess tyre wear? What size front and rear combo are you running? Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted May 3, 2003 Share Posted May 3, 2003 I have a uk tt without the front electronic spoiler and have no problems at all with grip or turning into a corner. Cant say i noticed a massive differance with or without it !! Can you explain a bit more exactly whats wrong ? Has this started since the p/s mod ? Link to comment Share on other sites More sharing options...
Terminator Posted May 3, 2003 Share Posted May 3, 2003 There are some front subframe bolts that are suposed to be checked at each service, many cars don't get then checked. I had a few light at the front at highspeed moments, so checked the bolts and they were way off torque, not finger tight but not up to the 148lbft they should have been. I am checking mine today along with an oil change. Link to comment Share on other sites More sharing options...
Wez Posted May 3, 2003 Share Posted May 3, 2003 Does anyone have a pic of these bolts? Link to comment Share on other sites More sharing options...
Mark Ayling Posted May 3, 2003 Share Posted May 3, 2003 Originally posted by Wez Does anyone have a pic of these bolts? I'd be interested too, Justin's doing some work on my car this month and I might get him to check them, as I might be doing some high speed driving shortly.... Link to comment Share on other sites More sharing options...
Steve W Posted May 3, 2003 Share Posted May 3, 2003 PHIL gave me THIS pic........ [bUT, haven't actually checked MINE yet... DOH!] Link to comment Share on other sites More sharing options...
Mark Ayling Posted May 3, 2003 Share Posted May 3, 2003 Nice one, ta Now here's where I sound really f* stupid.... Do "bits" have to be taken off to get to/tighten these bolts or are they easily accessible...? (Not that I'm going to do it myself, just wondering) Link to comment Share on other sites More sharing options...
Steve W Posted May 3, 2003 Share Posted May 3, 2003 " PHIL . . . ! ! ! ! " Link to comment Share on other sites More sharing options...
mos Posted May 3, 2003 Author Share Posted May 3, 2003 Yes i had geometry checked and it was in spec, i get inner tyre wear but apparently thats normal which is why i was asking if anybody has tried lance's settings. I am running 18" with 235,35,18's all round and i cant go wider due to my wheel width (7.5)(i was seen off by the company that supplied the wheels, i was new to the supra scene at the time). The handling was good before so i think i will check those bolts, fingers crossed. Link to comment Share on other sites More sharing options...
Justin Posted May 3, 2003 Share Posted May 3, 2003 Originally posted by Mark Ayling Nice one, ta Now here's where I sound really f* stupid.... Do "bits" have to be taken off to get to/tighten these bolts or are they easily accessible...? (Not that I'm going to do it myself, just wondering) Phil did mine for me. Just jack up ya mota and put axle stands under to stop yourself getting mashed. You can access all the bolts with your torque wrench then. J. Link to comment Share on other sites More sharing options...
mos Posted May 3, 2003 Author Share Posted May 3, 2003 sorry last post might have been confusing, the handling was good with the 18" before and the 30mm lowering, the geometry was done after the lowering and with the 18" and was in spec Link to comment Share on other sites More sharing options...
Terminator Posted May 3, 2003 Share Posted May 3, 2003 Now I am confused, are you saying that after fitting your 18" and lowering the car, the alignments were all in spec nothing needed adjusting:eek: Link to comment Share on other sites More sharing options...
mos Posted May 3, 2003 Author Share Posted May 3, 2003 Thats what toyota said, apparently it was close but it was o.k., i have since had it checked in portsmouth and again it came out o.k. Link to comment Share on other sites More sharing options...
Terminator Posted May 3, 2003 Share Posted May 3, 2003 Originally posted by Steve W PHIL gave me THIS pic........ [bUT, haven't actually checked MINE yet... DOH!] That’s the Daddy Steve. I check my fronts with every oil change @ 2500 to 3000 miles and the rears @ the second change. When I checked the rears today the big buggers were tight but the little ones on the OS were all about 5 degrees off their click on my torque wrench. Either my torque wrench is in need of replacement or they have loosened due to dry weather spirited cornering. Judging by my tyre wear I think it may be the latter. Link to comment Share on other sites More sharing options...
Terminator Posted May 3, 2003 Share Posted May 3, 2003 Originally posted by mos Thats what toyota said, apparently it was close but it was o.k., i have since had it checked in portsmouth and again it came out o.k. Thats lucky:p in many cases lowering throws alignment out. Link to comment Share on other sites More sharing options...
mos Posted May 3, 2003 Author Share Posted May 3, 2003 I do all my own servicing so the bolts have not been checked in nearly 3 years, good possibility i suppose, ill check tommorow. I was expecting the lowering to throw it out and was looking for adjustable top mounts, but when the check came out o.k. what was the point Link to comment Share on other sites More sharing options...
Steve W Posted May 3, 2003 Share Posted May 3, 2003 I may have to pop up your way sometime Phil, I really can't raise enough enthusiasm either at home OR at work (TOO lazy, then, TOO busy ! ) Maybe if I pop up to yours I might HAVE to do it ! ? {along with any other nasty-don't-really-fancy-doin-it jobs:( } " How's yer drive off fer oil staynz me ol' mucka ? ? " Lazy-FatS. Link to comment Share on other sites More sharing options...
Terminator Posted May 3, 2003 Share Posted May 3, 2003 No problem Steve, you bring the beers and we can check it over. BTW I dont spill oil, but if your Supra leaks, oil flog it. Just pick a sunny day as my garage is a bit crowded at the moment. Link to comment Share on other sites More sharing options...
Wez Posted May 3, 2003 Share Posted May 3, 2003 Thanks for the pic, will give me something to do tomorrow Link to comment Share on other sites More sharing options...
Roy Posted May 3, 2003 Share Posted May 3, 2003 have the same problem - front end goes light around 130-ish so have decided to get the front aer-lip fixed in the permanent down position and hope this will solve the floatiness. got new tyres going on as well and intend to do an alignment jobbie as well and between the two, am hoping to solve this. Link to comment Share on other sites More sharing options...
mos Posted May 3, 2003 Author Share Posted May 3, 2003 Thanks for the info people, keep us updated roy as mine goes light at about 80-90 on the bends Link to comment Share on other sites More sharing options...
Guest Martin F Posted May 3, 2003 Share Posted May 3, 2003 I've had Lance's alignment done on my supe and from what i can tell it has made high speed driving a little more twitchy. Has sorted the tyre wear and tramlining out, but at 100+ things are a little twitchier than i remember from before. Link to comment Share on other sites More sharing options...
