Josh42 Posted March 29, 2019 Share Posted March 29, 2019 Hi All, - MKIV remote shifter W58 gearbox, complete with 2JZ bell housing, gearbox mount, reverse sensor and speed sensor. The box was rebuilt in May 2016, with all new bearings by Agency Transmissions. - Clutch release fork and OEM release bearing (covered approximately 5k miles). - RPS Max clutch with street disc. This has been fitted for circa 10,000 miles, however, it still has plenty of life and the friction disc is OEM Toyota and therefore is easily replaced. - 2JZ OEM solid flywheel - MKIV manual prop shaft - Clutch slave cylinder - Master to slave hardline - Shifter (this will be the R154 shifter which will fit, but will sit slightly taller than a stock W58 shifter). What’s not included to complete the conversion: - transmission tunnel panel (available from Toyota) - manual gear surround - Clutch and brake pedal - master cylinder - bell housing bolts Offers around £1200 Link to comment Share on other sites More sharing options...
Josh42 Posted April 1, 2019 Author Share Posted April 1, 2019 Box will be removed this weekend and dropped with Agency. Reasonable offers accepted. Link to comment Share on other sites More sharing options...
rob_sri Posted April 7, 2019 Share Posted April 7, 2019 Very good box this drives lovely best of luck with your sale josh Link to comment Share on other sites More sharing options...
Josh42 Posted April 7, 2019 Author Share Posted April 7, 2019 rob_sri said: Very good box this drives lovely best of luck with your sale josh /QUOTE] Thanks Rob, it does drive lovely - in many ways actually feels better than the R154 replacing it! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Josh42 Posted May 3, 2019 Author Share Posted May 3, 2019 Bump Link to comment Share on other sites More sharing options...
L337 Posted May 26, 2019 Share Posted May 26, 2019 Is this still for sale? Link to comment Share on other sites More sharing options...
Josh42 Posted May 26, 2019 Author Share Posted May 26, 2019 I’ve got someone collecting Tuesday. I’ll let you know if anything changes mate Link to comment Share on other sites More sharing options...
Josh42 Posted May 28, 2019 Author Share Posted May 28, 2019 SOLD Link to comment Share on other sites More sharing options...
