New clutch needed any recommendations ??
keith 73tt
Apologies in advance chaps , I know this is somewhat of a "how long is a piece of string type question " but anywho....
My 6spd RZ is going for a head skim and new head gasket in the coming weeks..timing belt and water pump too of course.
The current clutch was in the car when I bought it a few years back and I can definitely feel some slippage when putting it through its paces at the upper end of the speed limit *cough:innocent:
The car is fairly stock and sitting at around the 330 bhp mark, and with regard to a new clutch I would like to future proof it for the 400- 500bhp mark.
I dont know enough about stage 1 ..stage 2 etc clutches and then of course you got them real pretty purple units from HKS and similar.
any help in the decision making process would be well received !
Thanks in advance :thumbs:
My car churns over 330bhp at the drive wheels so is probably around 380bhp at the flywheel and runs on the OEM clutch. I did have to replace its first clutch but not until it was 19 years old and had covered 109,000 miles, which is why the OEM clutch got replaced with an OEM clutch. It was refreshingly cheap to.
Thanks pal, i'll keep that in mind ! and see if any of the other lads on here have anything to say.:)
Chris Wilson does an OEM clutch that he uprates to handle a little more power. Very well priced as well. I have one in mine and it's class. Price may be different but here's a post from another thread. Drop him an email if you need to get hold of him as he doesn't use PM's on here
"I use the stock, brand new driven plate, as it is correctly
balanced, doesn't judder and will hold all but mega torque
highly modded engines or cars used for drag racing.
I modify a stock brand new cover to give more clamping force.
The reason I tooled up to do these is some of the aftermarket
US clutches I have fitted SEEM to be built from used cover
assemblies with reground friction surfaces, and a stronger
spring. I have had hellish trouble getting these to fully
release, because due to this seemingly thinner cast iron
friction face, the geometry of the clutch goes to pot, and
being a pull type clutch (the hydraulics pull the bearing
away from the engine, rather than the more normal push type)
it is a lot harder to effect a cure.
For 455 pounds plus VAT , you get a brand new driven
plate, a brand new modded cover, and a brand new release
bearing. I would rather fit myself so any complaints are down
to me, I see a lot of clutches damaged by people without the right gear
(a ramp and transmission jack, plus correct circlip tools and fitment)
or clutches fitted to patently *uggered flywheels. I will do a supply
only if you feel competent to tackle the job or are using a bona fide garage to
fit the clutch
Toyota use a dual mass flywheel (the flywheel is in 2 parts, an inner and
outer assembly, damped in the middle) which is now showing signs
of wear causing a lot of rattle when idling or on very light
throttle openings. For God knows what reason they are charging
about £270 + VAT for a new one, they look more like they should be
over 500 to me, but don't say anything :-) The very similar LUK dual
mass flywheel on Maseratis is nearly £1000 + VAT.... So if the flywheels
old enough or abused enough to be scored it should be replaced.
Fitting by myself will cost £175 + VAT.
Reply privately if interested please. [email protected]
Thanks."
Edited by Style (see edit history)
fit the clutch
Thanks."
Thanks mate , yep - I will deffo give him a shout !
Selling mine as new HKS LA if helps, nice clutch, drives like stock. Only selling as upgraded to RPS Carbon Triple, the HKS is supplied with new unused plates
http://www.mkivsupra.net/vbb/showthread.php?352062-HKS-LA-Twin-Plate-Clutch-Kit
Cheers mate,
TBH I hadnt seen your ad ! Looks like you are being very decent with the price but I have placed an order with Chris Wilson for one of his units.
best of luck with the sale anyway.
Cheers mate,
No dramas, all the best with the new set up
