Glover Posted March 20, 2019 Share Posted March 20, 2019 As with the title, what do people use for grease for the pins in the callipers? Link to comment Share on other sites More sharing options...
Frank Bullitt Posted March 20, 2019 Share Posted March 20, 2019 A small amount of Silicone/dielectric grease should be fine. Link to comment Share on other sites More sharing options...
Glover Posted March 20, 2019 Author Share Posted March 20, 2019 A small amount of Silicone/dielectric grease should be fine. Great, thanks Link to comment Share on other sites More sharing options...
Jellybean Posted March 27, 2019 Share Posted March 27, 2019 Ceratec is what manufacturers recommend now , especially for modern brakes But the above will also work for the pins https://mintex.com/copper-slip-vs-ceratec/?lang=en-gbr Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 27, 2019 Share Posted March 27, 2019 Stainless steel pins will stop you having to worry about grease getting on the friction surfaces. I see stainless steel pins And pistons... Link to comment Share on other sites More sharing options...
Glover Posted March 27, 2019 Author Share Posted March 27, 2019 Stainless steel pins will stop you having to worry about grease getting on the friction surfaces. I see stainless steel pins And pistons... Eventually I should be going down that route? Do you sell the items for this, and do you do an actual refurb service, 99% certain you’ll do a better job that I will!! Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 27, 2019 Share Posted March 27, 2019 I make and sell stainless steel pistons for all Supra calipers as well as any others if I have a pattern piston tp look at. I also do stainless steel pad locating pins for the UK type Supra calipers. I also sell seal kits that do a pair of calipers, be they fronts or rears, Jap or UK spec. Whilst I will rebuild calipers I domn't want to get into show finish powder coating, all I offer is Kephos coating in satin black. It's what F1 used on suspension parts before most were made in carbon fibre instead of steel. Link to comment Share on other sites More sharing options...
Glover Posted March 27, 2019 Author Share Posted March 27, 2019 Great, I’ll keep this in mind as well then!! I have got the JSpec brakes so I would like to eventually move to a bigger brake set up, so I’ll deffo keep this is mind ! Cheers for the info!!! Link to comment Share on other sites More sharing options...
Jellybean Posted March 27, 2019 Share Posted March 27, 2019 I make and sell stainless steel pistons for all Supra calipers as well as any others if I have a pattern piston tp look at. I also do stainless steel pad locating pins for the UK type Supra calipers. I also sell seal kits that do a pair of calipers, be they fronts or rears, Jap or UK spec. Whilst I will rebuild calipers I domn't want to get into show finish powder coating, all I offer is Kephos coating in satin black. It's what F1 used on suspension parts before most were made in carbon fibre instead of steel. Do you have a pic of the finish Chris, kephos Link to comment Share on other sites More sharing options...
Wishieftrottle Posted March 27, 2019 Share Posted March 27, 2019 This is, what I used on my calipers… ATE Link to comment Share on other sites More sharing options...
