Noz Posted March 15, 2019 Share Posted March 15, 2019 Hi all, so a random one for you this evening. My parents own a property that has a road separating them from their garden, at the end of the garden are the stables. I'm setting up a CCTV system so my parents can see the horses. I'm unsure the best way to transfer signal from the stables up the garden and across the road. I was thinking to use a WiFi extender across the road to the small outbuilding opposite the house (it's a medium-sized road nothing too mad) and then ethernet cable down the garden. But I've found some wireless systems that might be better attaching to the house high enough, I'm just not sure really. Any advice? https://www.amazon.co.uk/Wireless-Waterproof-Installation-Controller-EAP110-Outdoor/dp/B01N4EGN6H/ref=cm_cr_arp_d_product_top?ie=UTF8 Quote Link to comment Share on other sites More sharing options...
Annabella Posted March 15, 2019 Share Posted March 15, 2019 (edited) Never tried one of those, but have used a lot of tplink stuff in the past and have worked fine. The theory is good, if it doesn't work then revert to the other plan using the tplink on the small outhouse. How many meters are the stables from the house? If you go the other route the maximum ethernet cable length is 100m unless boosted with a switch. Edited March 16, 2019 by Annabella Must have had brain fade not 30m!! (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted March 15, 2019 Share Posted March 15, 2019 Assuming you have electricity there, have another network connection installed in the stables? Quote Link to comment Share on other sites More sharing options...
Annabella Posted March 15, 2019 Share Posted March 15, 2019 You'd need another broadband and landline connection for that David. Quote Link to comment Share on other sites More sharing options...
David P Posted March 15, 2019 Share Posted March 15, 2019 That is what I meant. I am far from an IT Expert, but it is a solution that is guaranteed to work. Quote Link to comment Share on other sites More sharing options...
bonus_2000 Posted March 16, 2019 Share Posted March 16, 2019 If you can run a length of cat 5e/6 up there directly, you can run to a maximum of 100m before the signal will break down and it will need boosting. Couple that with a poe camera and a poe injector at your house and you will be laughing if you don't have power in the stables. Quote Link to comment Share on other sites More sharing options...
bonus_2000 Posted March 16, 2019 Share Posted March 16, 2019 If you can run a length of cat 5e/6 up there directly, you can run to a maximum of 100m before the signal will break down and it will need boosting. Couple that with a poe camera and a poe injector at your house and you will be laughing if you don't have power in the stables. /QUOTE]Failing that you could look at some of the ubiquiti point to point wireless stuff maybe if a direct lan connection isn't possible? Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
rider Posted March 16, 2019 Share Posted March 16, 2019 If the stables and the house are on the same mains meter than its a simple solution to use DLAN plugs. You just plug an Ethernet port off your router into a DLAN plug and then any other DLAN plugs on the same ring mains will have network access and internet through the router. I have that setup for my detached garage/up stairs home office. If you have separate mains meters than you need to go for a network wifi bridge. That requires a access point and transmitter terminal, one plugged into the home router and the other into a second router in the outlying buildings. Plenty for sale on eBay and loads of videos on youtube how to set these up. The only requirement is line of sight between the two units. Quote Link to comment Share on other sites More sharing options...
Noz Posted March 16, 2019 Author Share Posted March 16, 2019 Getting my dad to measure the estimated distance today! If you can run a length of cat 5e/6 up there directly, you can run to a maximum of 100m before the signal will break down and it will need boosting. Couple that with a poe camera and a poe injector at your house and you will be laughing if you don't have power in the stables. /QUOTE] 100m is pretty far. Seems a good idea to use a PoE camera that would be ideal really. Best way to jump the Wi-Fi across the road to the Ethernet cable? Quote Link to comment Share on other sites More sharing options...
Noz Posted March 16, 2019 Author Share Posted March 16, 2019 If the stables and the house are on the same mains meter than its a simple solution to use DLAN plugs. You just plug an Ethernet port off your router into a DLAN plug and then any other DLAN plugs on the same ring mains will have network access and internet through the router. I have that setup for my detached garage/up stairs home office. If you have separate mains meters than you need to go for a network wifi bridge. That requires a access point and transmitter terminal, one plugged into the home router and the other into a second router in the outlying buildings. Plenty for sale on eBay and loads of videos on youtube how to set these up. The only requirement is line of sight between the two units. I'll do some research into a DLAN plug. That sounds interesting. Quote Link to comment Share on other sites More sharing options...
Noz Posted March 16, 2019 Author Share Posted March 16, 2019 Sadly it's on a different ring main I've just been told. Quote Link to comment Share on other sites More sharing options...
RobUK Posted March 16, 2019 Share Posted March 16, 2019 I’ve got WiFi working over 1.2km so you should easily be able to do what you require..... it might be worth putting up a simple diagram showing distances and heights, if you mounted a WiFi dish on the house you should be able to pick up that signal in the stable block..... what you need to consider though are the obstructions, such as trees etc.... PM me if you want Rob Quote Link to comment Share on other sites More sharing options...
Ric Posted March 16, 2019 Share Posted March 16, 2019 mesh is better than a repeater, theres various available. I use Linksys velop system at home and it works great. All depends how far it actually is though before you get into aligned dishes etc. Quote Link to comment Share on other sites More sharing options...
