cainhead Posted March 13, 2019 Share Posted March 13, 2019 (edited) Hello, Had a problem with my car under full boost. Its seems to feel like a misfire and the description of article 2a in the below link gives a pretty accurate account of what im getting, especially as its on a single turbo as described in the link. http://www.mkivsupra.net/vbb/showthread.php?35931-Misfire-under-boost-(plus-misfire-diagnosis) So my question is, does anyone have a set of fully working coil packs that they wouldn't mind me borrowing for a quick test before I go out and spend a small fortune on new ones. Im in outter SW London and happy to travel or pay postage if anyone could help me out. I cant remember if it matters but its a UK spec. Many thanks in advance for any help. Edited March 13, 2019 by cainhead (see edit history) Link to comment Share on other sites More sharing options...
peter richards Posted March 13, 2019 Share Posted March 13, 2019 have you checked the clips Link to comment Share on other sites More sharing options...
wile e coyote Posted March 13, 2019 Share Posted March 13, 2019 As peter said These are very common to go brittle Change them regardless if you haven’t already Link to comment Share on other sites More sharing options...
cainhead Posted March 13, 2019 Author Share Posted March 13, 2019 As peter said These are very common to go brittle Change them regardless if you haven’t already I changed these not too long ago. I checked these and they still go on and off without feeling like they are going to brake. The issue only started when the car had gone single. Link to comment Share on other sites More sharing options...
wile e coyote Posted March 13, 2019 Share Posted March 13, 2019 Ok Link to comment Share on other sites More sharing options...
peter richards Posted March 13, 2019 Share Posted March 13, 2019 ok, could it be a fuel issue when hot Link to comment Share on other sites More sharing options...
rider Posted March 13, 2019 Share Posted March 13, 2019 First stop should be to grab a multi-meter and check the resistance of the six coils, first that there is a resistance and its pretty uniform across all coils. It's normally about 13k ohms from memory but that is failing as I age so do check that out. If you then spot you have a dud one then just replace that one with a new OEM fitment coil. I have a few of those in my Supra parts storage area so feel free to PM me if you need one. Link to comment Share on other sites More sharing options...
cainhead Posted March 13, 2019 Author Share Posted March 13, 2019 okay good shout, ill pop out to the garage later and give that go. Link to comment Share on other sites More sharing options...
cainhead Posted March 13, 2019 Author Share Posted March 13, 2019 ok, could it be a fuel issue when hot Im not sure its happening long enough after starting. Yesterday is was about 5 mins in. Link to comment Share on other sites More sharing options...
mellonman Posted March 13, 2019 Share Posted March 13, 2019 take them out one by one by the 2 screws take the spark plug out of the car and then put the plug back in the coil start the car and put the coil on any bit of metal like the lifting eye and see how good your spark is then move the coil up the to the lifting eye and see if the spark is leaking , I had 18 coils and struggled to find 4 that worked with out leaking from the coil stem. wear rubber gloves as when you hold one that's leaking you get a shock Link to comment Share on other sites More sharing options...
shaz2010 Posted March 13, 2019 Share Posted March 13, 2019 Hello, Had a problem with my car under full boost. Its seems to feel like a misfire and the description of article 2a in the below link gives a pretty accurate account of what im getting, especially as its on a single turbo as described in the link. http://www.mkivsupra.net/vbb/showthread.php?35931-Misfire-under-boost-(plus-misfire-diagnosis) So my question is, does anyone have a set of fully working coil packs that they wouldn't mind me borrowing for a quick test before I go out and spend a small fortune on new ones. Im in outter SW London and happy to travel or pay postage if anyone could help me out. I cant remember if it matters but its a UK spec. Many thanks in advance for any help. Hi mate I had the same thing, I changed the coil pack clips and still the same then changed the plugs to iridium still the same! The coils were the next thing to change out as they cost the most. Bought some oem coil packs and it sorted the misfire! Never pulled better in all my time I’ve had it 7 years. The misfire for mine was when at high boost around 5-6k revs and it sort of splutter like it was losing power but not like fuel cut! Did it some times then not at all in the end it was happing all the time. Coil must have completely broke down inside. Hope this helps, I’ll pm u details if u want. I have the old coils still but if I were you I’d get new. I’m all so a Uk spec Link to comment Share on other sites More sharing options...
squiffy Posted March 14, 2019 Share Posted March 14, 2019 I'm also getting this problem, its had new clips and new iridium plugs and a set of whifbitz coil packs last year so I'm hoping it's not one of them gone! Not sure what else to check Could the igniter pack cause problems like this? Link to comment Share on other sites More sharing options...
shaz2010 Posted March 14, 2019 Share Posted March 14, 2019 I'm also getting this problem, its had new clips and new iridium plugs and a set of whifbitz coil packs last year so I'm hoping it's not one of them gone! Not sure what else to check Could the igniter pack cause problems like this? /QUOTE] That would of been my next thing to change out mate. Link to comment Share on other sites More sharing options...
cainhead Posted March 17, 2019 Author Share Posted March 17, 2019 Just to update this for future reference it was the coil packs. My symptoms were as I said from the technical ref link in my first thread. Thanks for all the replies and help. Link to comment Share on other sites More sharing options...
