Chingy Posted March 10, 2019 Share Posted March 10, 2019 Repairs or simply just Spares! Offered if either of these can help someone out..... if not don’t worry I will make a lamp or something out of them. Set of 2JZ GTE Carrillo Rods & Crank, The engine spun bearing on Rod 6 during a dyno pull. Bearings used when it failed where Toyota OEM so softer than replacement race bearings. Car was shut down immediately after the run so not driven around for miles on a road failure. Rods all have CARR bolts Rods 2,3,4,5 nice condition. Rod 6 spun the bearing will need replacing Rod 1 measures (0.16) ....recommended wear limit (0.20) I would also replace Rods £SOLD. Crank is in good condition but will need a visit to the machine shop for a regrind due to Rod 6 bearing failure Crank £SOLD ** Link to comment Share on other sites More sharing options...
Al Massey Posted March 11, 2019 Share Posted March 11, 2019 Where abouts are you located? Interested in the crank. Link to comment Share on other sites More sharing options...
Chingy Posted March 11, 2019 Author Share Posted March 11, 2019 Where abouts are you located? Interested in the crank. Sussex near Gatwick....5 mins from SRD if that helps Link to comment Share on other sites More sharing options...
Al Massey Posted March 11, 2019 Share Posted March 11, 2019 Oh a bit of a trek. Guessing postage would cost a bomb? Link to comment Share on other sites More sharing options...
Chingy Posted March 11, 2019 Author Share Posted March 11, 2019 Oh a bit of a trek. Guessing postage would cost a bomb? Just weighed and measured it......coming out at £15 for 48hr parcel force if helps Link to comment Share on other sites More sharing options...
Al Massey Posted March 11, 2019 Share Posted March 11, 2019 Just weighed and measured it......coming out at £15 for 48hr parcel force if helps Oooo that’s not too bad. I’ll let you know by the weekend mate Link to comment Share on other sites More sharing options...
Chingy Posted March 11, 2019 Author Share Posted March 11, 2019 Oooo that’s not too bad. I’ll let you know by the weekend mate No dramas, cheers Link to comment Share on other sites More sharing options...
