sweettom Posted March 5, 2019 Share Posted March 5, 2019 Hi, One of my friend is making a single turbo conversion with a nonvvti 2jz GE block and can't decide how could he take the oil pressure from the block to the single turbo. Maybe do you have any idea what's the best way to do this? Thanks for help.[emoji4] Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 5, 2019 Share Posted March 5, 2019 a) Use a lexus 2j oil filter housing bolt as this comes with a hole for oil pressure sensor pre drilled & tapped. You can then screw a 1/8 BSP -> AN fitting and use that to feed your turbo. b) Run an oil sandwich plate in between oil filter and oil filter hosuing, and run your feed from that. c) Remove the factory oil pressure switch (behind AC compressor), then you can use an 1/8 BSP to AN adapter to feed your single turbo. I've tried all of the above at some point or another and all seem to work. Option a) is the most OEM looking Quote Link to comment Share on other sites More sharing options...
sweettom Posted March 5, 2019 Author Share Posted March 5, 2019 Thank you so much for the quick help. I was already thinking on the b and c option. Quote Link to comment Share on other sites More sharing options...
