Slide 2jz Posted March 3, 2019 Share Posted March 3, 2019 dıff oıl lıght comes on after sıdeways ın track, and dıff oıl coller motor oıl pump stays on runnıng whıle swıtch open!! are there problemm wıth sensor? any exprıced ıdea... thanks Quote Link to comment Share on other sites More sharing options...
Tyson Posted March 3, 2019 Share Posted March 3, 2019 Is yours a UK car with the cooler setup ? Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 3, 2019 Share Posted March 3, 2019 your probably pushing all the oil to one side when going sideways which then triggers the sensor , this might indicate low oil level Quote Link to comment Share on other sites More sharing options...
Slide 2jz Posted March 3, 2019 Author Share Posted March 3, 2019 (edited) —— Edited March 3, 2019 by Slide 2jz (see edit history) Quote Link to comment Share on other sites More sharing options...
Slide 2jz Posted March 3, 2019 Author Share Posted March 3, 2019 Is yours a UK car with the cooler setup ? My one has uk spec brakes but car is jap spec Tapatalk kullanarak iPhone aracılığıyla gönderildi Quote Link to comment Share on other sites More sharing options...
Slide 2jz Posted March 3, 2019 Author Share Posted March 3, 2019 your probably pushing all the oil to one side when going sideways which then triggers the sensor , this might indicate low oil level Oww! That is dangers for clutch system in lsd! When i bought it i have been told after market lsd in diff, which oil can i use for top oil up level Tapatalk kullanarak iPhone aracılığıyla gönderildi Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 3, 2019 Share Posted March 3, 2019 What does this diff oil light look like? Quote Link to comment Share on other sites More sharing options...
Slide 2jz Posted March 3, 2019 Author Share Posted March 3, 2019 What does this diff oil light look like? Side of oil level light i have got sign says “diff oil” And when ignition is open diff oil coller pump start working!! Tapatalk kullanarak iPhone aracılığıyla gönderildi Quote Link to comment Share on other sites More sharing options...
Ric Posted March 3, 2019 Share Posted March 3, 2019 Those arent diff oil lights. There is no diff oil sensor. AFAIK From your picture It's Engine Check Light > Engine Oil Pressure (Red) > Engine Oil Level (Orange) Quote Link to comment Share on other sites More sharing options...
Slide 2jz Posted March 3, 2019 Author Share Posted March 3, 2019 Those arent diff oil lights. There is no diff oil sensor. AFAIK From your picture It's Engine Check Light > Engine Oil Pressure (Red) > Engine Oil Level (Orange) Right side of oil level light “diff oil” light flash on my car, this picture from internet because car is not with me at the moment Thanks Tapatalk kullanarak iPhone aracılığıyla gönderildi Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 3, 2019 Share Posted March 3, 2019 Diff oil is oil temperature on UK spec cars http://www.mkiv.co.uk/vbb/showthread.php?242822-About-Yellow-Oil-Lamp-! Quote Link to comment Share on other sites More sharing options...
Tyson Posted March 3, 2019 Share Posted March 3, 2019 Diff oil is oil temperature on UK spec cars http://www.mkiv.co.uk/vbb/showthread.php?242822-About-Yellow-Oil-Lamp-! This. Which is why I asked if you had a UK car. The cooler and pump set up was only installed on UK / EU cars and the light as far as I am aware was only those cars. Quote Link to comment Share on other sites More sharing options...
