rg500 Posted February 28, 2019 Share Posted February 28, 2019 I am in the process of a na-t project and wanted to know if a tt intake manifold Would fit on a non turbo. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 28, 2019 Share Posted February 28, 2019 (edited) With some cutting and welding yes. Not as a straight swap. EDIT The placement of the intake ports on the TT head is slightly different than the na, meaning the TT intake manifold will not bolt directly onto the head. It would be possible to cut and splice TT intake and NA lower runners so that the TT upper intake manifold bolts on but all the examples I've seen leave the intake sitting very high and towards the right and the port matching is still a nightmare. Edited February 28, 2019 by Frank Bullitt Info added. (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted February 28, 2019 Share Posted February 28, 2019 No. Flanges are different. I have seen TT inlet manifolds that have their runners cut and welded onto NA lower runners, seems to work ok. Quote Link to comment Share on other sites More sharing options...
rg500 Posted February 28, 2019 Author Share Posted February 28, 2019 Thanks for the advice i will stick to the original intake for now. Quote Link to comment Share on other sites More sharing options...
AC93 Posted February 28, 2019 Share Posted February 28, 2019 I'm going NA-T and getting a SSI intake manifold Quote Link to comment Share on other sites More sharing options...
