jza800 Posted February 21, 2019 Share Posted February 21, 2019 (edited) Hi I Have a j-spec supra tt, where the slip con off light in the dash is on all the time, when i have ign on the yellow slip con off and green slip con light up, but when the car starts up, the yellow slip con off light up.. what can the problem be? a relay or??? Edited February 23, 2019 by jza800 (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 22, 2019 Author Share Posted February 22, 2019 No one?? Link to comment Share on other sites More sharing options...
PJJ Posted February 22, 2019 Share Posted February 22, 2019 Hi Sorry but I can't really understand your description of the fault in the way it's written. Can you elaborate? You say the light stays on, do you mean stays lit or it keeps flashing as if it's de-activated? Have you read my post below to see if it helps as mine was faulty also? - I've written what fixed mine to help others with same issue. http://www.mkivsupra.net/vbb/showthread.php?348655-Hit-pothole-Now-the-slip-control-off-amp-OD-off-lights-are-flashing Link to comment Share on other sites More sharing options...
jza800 Posted February 22, 2019 Author Share Posted February 22, 2019 Hi Mine does not flashing the light stays on when the car is startet. And can not turn it off on the slip con button under the radio. I have scarch but the only threads i can find is when it flashes but mine stays on and dont flasch Link to comment Share on other sites More sharing options...
PJJ Posted February 22, 2019 Share Posted February 22, 2019 Yes I think most people have the flashing issue. Have you tried: - Looking at the fuses (trac 1 & 2 in engine bay) - Testing the switch below radio to turn it off to see if faulty - Trac sensor on the engine Sorry can't help more. Try ringing Whifbitz and see what they suggest as they might of heard of it before. Link to comment Share on other sites More sharing options...
David P Posted February 22, 2019 Share Posted February 22, 2019 Hi Mine does not flashing the light stays on when the car is startet. And can not turn it off on the slip con button under the radio. I have scarch but the only threads i can find is when it flashes but mine stays on and dont flasch Maybe the site can't understand your flavour of Dick licks here? Try "scarch"-ing with correct spelling? Link to comment Share on other sites More sharing options...
Scooter Posted February 22, 2019 Share Posted February 22, 2019 Does the slip/traction control work? have you tested that, I suspect it doesn't which then leads us on to checking for fault codes.... Link to comment Share on other sites More sharing options...
jza800 Posted February 22, 2019 Author Share Posted February 22, 2019 I have checkes the fuses, and No fuse blown. Have checke for error code, and No erro codes found. When you check e1 and tc the abs and slip con flashes fast. So No error code stored. Link to comment Share on other sites More sharing options...
drift_bear Posted February 22, 2019 Share Posted February 22, 2019 Maybe the site can't understand your flavour of Dick licks here? Try "scarch"-ing with correct spelling? Never thought that English isn’t the OP’s main language? So that’s why it’s hard to make out his question you’re the one recently moaning about people using other places than the forum for information, now someone uses the forum to ask a question and respond like that Link to comment Share on other sites More sharing options...
Scooter Posted February 22, 2019 Share Posted February 22, 2019 I think it should only be the 'engine' symbol that flashes regularly that indicates no codes? Abs and slip flashing isn't normal.........have you tried an emergency stop (to test ABS is operational) and flooring the car from standstill on a slippery surface or, on a t junction to initiate wheel spin (to test the traction control) Link to comment Share on other sites More sharing options...
Scooter Posted February 22, 2019 Share Posted February 22, 2019 Never thought that English isn’t the OP’s main language? So that’s why it’s hard to make out his question you’re the one recently moaning about people using other places than the forum for information, now someone uses the forum to ask a question and respond like that I like David and his knowledge in some areas is huge but I agree he is particularly grumpy right now!! Link to comment Share on other sites More sharing options...
drift_bear Posted February 22, 2019 Share Posted February 22, 2019 I like David and his knowledge in some areas is huge but I agree he is particularly grumpy right now!! I’m no means saying he doesn’t contribute with information and helping members, like you said he just seems grumpy recently that’s all I was trying to get over Link to comment Share on other sites More sharing options...
Scooter Posted February 22, 2019 Share Posted February 22, 2019 Yeah it need saying I think I was just trying to pat him on the back/keep the peace at the same time Link to comment Share on other sites More sharing options...
jza800 Posted February 22, 2019 Author Share Posted February 22, 2019 Abs and slip con off only flash when you bridge e1 and tc to test for error codes. I can make Wheels spin, but have not checked if the abs work.. The abs light dont light up then the car us running. I am not from England, So My english is not the best. Link to comment Share on other sites More sharing options...
David P Posted February 22, 2019 Share Posted February 22, 2019 (edited) Never thought that English isn’t the OP’s main language? So that’s why it’s hard to make out his question you’re the one recently moaning about people using other places than the forum for information, now someone uses the forum to ask a question and respond like that The site search can't compensate for incorrect spelling like Google, spelling mistakes on here are clearly underlined in red and the correct spelling is only a right click away, which is not rocket science in any language. P.S. My posting is on topic and waaay more positive than yours. Edited February 22, 2019 by David P (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 23, 2019 Author Share Posted February 23, 2019 i did found the problem... Link to comment Share on other sites More sharing options...
David P Posted February 23, 2019 Share Posted February 23, 2019 Good for you,,,,, but no good for others! Please resolve the thread properly and post what the problem was, then next time another member has the same issue they will be able to find the solution. Link to comment Share on other sites More sharing options...
jza800 Posted February 23, 2019 Author Share Posted February 23, 2019 Good for you,,,,, but no good for others! Please resolve the thread properly and post what the problem was, then next time another member has the same issue they will be able to find the solution. You really have an attitude problem you know that!!!! Link to comment Share on other sites More sharing options...
David P Posted February 23, 2019 Share Posted February 23, 2019 If everyone had the same attitude as you, there would be no solutions to be found in the technical pages. Link to comment Share on other sites More sharing options...
The Raven Posted February 23, 2019 Share Posted February 23, 2019 You really have an attitude problem you know that!!!! Regardless. Having the issue fix explained would be most helpful Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 24, 2019 Share Posted February 24, 2019 (edited) So how did you solve this problem? It would be nice for your to post up what you have done or how you solved this so future members can search and find a potential answer. Regardless of Davids replies towards you, are you the sort of member who only wants to come on here when you have a problem to get it solved or are you prepared to put back into the club what you get out of it? Coming from someone who has taken the time to reply to problems you have had in the past I am surprised to see this sort of behaviour. Are you prepared to do the decent thing and let others know the answer? Edited February 24, 2019 by Frank Bullitt (see edit history) Link to comment Share on other sites More sharing options...
jza800 Posted February 24, 2019 Author Share Posted February 24, 2019 And you think it is ok to talk to people like the as david do, i don't.. it is not first time he does that to me, not all are good to write in a language they not are born at.. i have written as good as i could, so i don't think i deserve that treatment from him, as others has said to... but to get back to your question my problem is the trottle controle ecu... Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 24, 2019 Share Posted February 24, 2019 (edited) And you think it is ok to talk to people like the as david do, i don't.. it is not first time he does that to me, not all are good to write in a language they not are born at.. i have written as good as i could, so i don't think i deserve that treatment from him, as others has said to... but to get back to your question my problem is the trottle controle ecu... Since when did sticks and stones stop being relevant? What goes on between you and David has absolutely nothing to do with me or anyone else reading the posts in this thread for that matter. I'm sure your a big boy with strong shoulders, just brush yourself off and move on. Thank you for posting your findings and finally posting your answer to the other problem thread you solved. Much appreciated. Edited February 24, 2019 by Frank Bullitt Spelling. (see edit history) Link to comment Share on other sites More sharing options...
David P Posted February 24, 2019 Share Posted February 24, 2019 And you think it is ok to talk to people like the as david do, i don't.. it is not first time he does that to me, not all are good to write in a language they not are born at.. i have written as good as i could, so i don't think i deserve that treatment from him, as others has said to... It's called "satire" which is a typical British old-school sense of humour that most women, several other Nationalities and all insecure young men don't understand. Link to comment Share on other sites More sharing options...
