Thomas.B Posted February 18, 2019 Share Posted February 18, 2019 (edited) Hi! I will be replacing my cambelt, ac belt, tensioner and if there are other things that are good to replace at the same time? Does anyone have the toyota numbers for the parts needed, would be greatly appreciated! Found the following: Engine Drive Belt tensioner (TT 6spd) 16620-46070 Engine Drive Belt tensioner (NA - TT Auto) 16620-0W025 Thanks! Edited February 18, 2019 by Thomas.B (see edit history) Quote Link to comment Share on other sites More sharing options...
jim_supra Posted February 18, 2019 Share Posted February 18, 2019 Hi, Depends how far you want to go on replacing parts, but I'd be putting on a new water pump while I had access, and also inspecting the crank pulley for signs of the rubber splitting and replacing it if neccessary, then a new pulley bolt, cam cover gaskets etc. For part numbers I use japan-parts.eu see link below. It's fairly straightforward to use, you can change/ select the variant of your car in tabs towards the top of the page. http://japan-parts.eu/toyota/eu/1994/supra/jza80r-ajpvzw/3_291230_009_/tool-engine-fuel Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted February 18, 2019 Author Share Posted February 18, 2019 Thanks! Water pump is changed a few years back but I could ofcourse change again, only done at the most 1000miles since the build 5 years ago. Just want everything to be tiptop Quote Link to comment Share on other sites More sharing options...
