Turbo Oil feed
rg500
I'd just go with a sandwich plate as you'll probably need an oil cooler as well. The GE engine doesn't have the heat exchanger unit on the oil filter housing like the GTE. Otherwise the union bolt, either the Lexus one or just modify your own with a thread, and the oil pressure sensor are both good locations to get an oil feed for the turbo.
