Greddy Profec B spec II Set Up
Icsea
I recently changed the alternator in my car and my boost controller has reset itself and my boost gauge also isn't working at all now.
Hi
Set xx
Gain xx
Set gain x.xx
Warning x.xx
Limiter xx
Lo
Set xx
Gain xx
Set gain x.xx
Warning x.xx
Limiter xx
i have no idea what the values should be, ive some settings for low but would prefer the input of other members here.
Thanks
I normally put around 10-15% gain. Set warning to 1.3 bar, Set limiter to 20%.
The only thing left after those settings is your SET value. This changes from car to car, and what weather conditions you are in.
Start with set at 30, see what boost that gives you then either reduce or increase depending on how far off from your boost target you are
