rg500 Posted February 5, 2019 Share Posted February 5, 2019 (edited) What diameter hole do you need on the sump for the oil return line from the turbo as it isn’t pressure related what’s the minimum diameter hole needed. Edited February 5, 2019 by rg500 Photo (see edit history) Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted February 5, 2019 Share Posted February 5, 2019 You should be using a minimum of AN10 for your return line. ID of AN10 is roughly 13mm, so at minimum hole should be that much. Usually I drill the whole area out Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 5, 2019 Share Posted February 5, 2019 As above, AN-10 Quote Link to comment Share on other sites More sharing options...
rg500 Posted February 6, 2019 Author Share Posted February 6, 2019 Did you do it with the engine still in or did you take the engine out. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 6, 2019 Share Posted February 6, 2019 Definitely take the engine out. I believe it can be done if you drop the front subframe to remove the sump, but definitely don’t drill it with the sump in place. The engine can be removed in a couple of hours complete with the gearbox so it’s really no reason not to. Quote Link to comment Share on other sites More sharing options...
rg500 Posted February 6, 2019 Author Share Posted February 6, 2019 Which is easier dropping the subframe or taking the engine out. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 6, 2019 Share Posted February 6, 2019 I’d personally drop the engine. Will give you the opportunity to replace the cambelt, water pump etc while you’re there Quote Link to comment Share on other sites More sharing options...
rg500 Posted February 6, 2019 Author Share Posted February 6, 2019 I’ve just had those changed 3 months ago. Quote Link to comment Share on other sites More sharing options...
rg500 Posted February 7, 2019 Author Share Posted February 7, 2019 I have just been to my mechanic which does most of the work on my supra and he quoted £200 fro doing the oil return. Quote Link to comment Share on other sites More sharing options...
