Full service and cambelt etc - would you upgrade cams at the same time?
Thomas.B
Hey!
Will be doing a big service in march and also the cambelt, tensioners etc.
Since the single build i've been thinking of upgrading the cams to 264 or something mildish.
What would you do?
Current spec:
Rebuilt stock block using Apr headbolts / Acl gold head bearing /new harmonic dampened/ Power enterprise Kevlar timing belt/ greedy fan belt
New oil pump
S/S turbo manifold
S/S down pipe
S/S mid pipe
Sound performance Sp67 .81 Gt turbo with antisurge housing
Aero motive FPR
Aero motive 100 micron fuel filter
Hks Dli 2 ignition amplifier
Dual walbro fuel pumps
Aem ems version 1
Aem 3.5 bar map sensor
Aem air filter
Aem wide and
19 row Greedy oil cooler
Mocal relocation oil filter plate
4inch FMIC
3 inch custom piping
Trial 44mm waste gate
Trial 50mm Bov
880cc precision fuel injectors
Sound performance top mount fuel rail
AAP electric dual fans /with custom relays and fuses
Centre force dual friction clutch
Uk front 4 pot brakes
S/S braided lines
Defi oil pressure/ oil temp/Egt gauges / defi controller
-12an fuel lines
Is the car auto or manual? VVT-i or non VVT-i?
Is the head coming off or is it just a cam swap? Stem seals would be a must if they are still OEM.
Other item to consider whilst you are there could be;
- Coil Pack Clips
- Coil Packs
- Water Pump Gasket
- Water Pump
- Thermostat
- Tensioner
- Idler
- Idler Bolt
- Idler Washer
- Timing Belt Tensioner Hydraulic Capsule
- Crank Sprocket. If non VVT-i get a new one and weld it up to stop it separating.
- Oil Pump
- Oil Pump Seal
- Lexus SC430 Oil Filter (its larger that the Supra one)
- Crank Pulley
- Crank Washer
- Crank Bolt
Hi!
Non vvti, v160
Water pump, oil pump etc is already new, well changed when the build was going on and it's only covered 500miles the last 4-5 years.
I'm doing the belt etc mostly as the tensioner is acting up and making a little sound. And if I'm doing the belt I might continue
More power, not necessarily but ready for more and being able to get better response mostly.
