Hitbox Junkie Posted January 27, 2019 Share Posted January 27, 2019 Make: Toyota Supra Aerotop Black 202 Model: 6Speed, Single Turbo Aerotop Year:1993 Facelift: no Mileage: 110485 KM MOT remaining: 20th February 2019, ( it is going to SRD and will have a Fresh MOT ) Service history: I bought this car as a non running shell and did not have any service history. It has been built at SRD and I have all the invoices from when i took the car, It is going in for its service with its mot in February. Car's location: Poole/Bournemouth Modifications: built from a NA AUTO aerotop shell to a 6speed (V160), Single Turbo 2JZ-GTE, UK Spec Auto Big case Diff with UK Spec brakes all round running EBC redstuff brake pads and EBC brake discs. Fully flocked interior Good bits: Built by SRD its ready to take and has been reliable. Bad bits: could do with audio being set up for it, Comes with a android head unit, needs front speakers. age related paint marks on the car. Paint does come up very well when cleaned and polished. previous person with the dash cut the middle bit to fit a double din and didn't do a very good job. Tiny bubble on the boot bottom left, and skid skirt has a knock from when i bought the car just focused on the mechanical things before the cosmetic. If i am to keep her then id consider a blow over or full respray to get everything 100% and id possibly go with twins body kit or stick to stock. Front bumper has a small crack, un noticable from a distance. PRICE: £25,000 offers welcome. Please PM for contact details. Project Thread: http://www.mkivsupra.net/vbb/showthread.php?318887-6Speed-Aerotop-Single-Turbo-Project-Aurora-(PICS!) Spec: Body: 1993 Areotop NA Auto Engine: Boost logic manifold Precision 67 dual ball-bearing turbo 3.1L 2JZ-GTE stock block, rebuilt by SRD becuase it was in a bad state when we opened it at srd . 1000cc Apr injectors Gates Racing fanbelt Nur Sepc R exhaust Bore size: 87mm Running larger bearings The big ends are stock size Wiseco pistons Spool rods stock head thats been machined with Crower cams 264s ECU: Syvecs S6 Sensors and Harness Toucan Display Unit Drive Train: 6 Speed conversion getrag V160 AUTO LSD Suspension: Chris Wilson suspension setup (I don't know specifically) Wheels: Volk Racing GTS wheels made by Rays Wheels UK Brakes with braided lines Parana front discs with ebc redstuff brake pads Mtec rear discs with ebc redstuff brake pads A list of all the bits that have been done in 2016 til late 2017 when it was finally completed and driving on the road. Skimmed block Oil squitter delete Toyota engine gasket kit Jspec Head work, Clean grind valves, cut valve seats, skim 0.006 Reshrim valve clearances Toyota Oil Pump OEM Toyota Core plug block 35mm Toyota water pump 2jz OEM Toyota Oil filter housing O ring Toyota modine O ring Large Toyota thermostat Toyota Locking Nut Toyota Oil filter Gates Kevlar Racing Belt Toyota Timing Belt Idler Wheel Paint/ and materials SRD Rebuilt 100amp alternator Toyota Coil Pack Connectors No wires T4 Divided Turbo Gasket Toyota Locking Nut Studs For Turbo Toyota PVC Grommet SRD Turbo Water Line Kit Top Water Neck Mod for single Turbo Used Toyota Timing Pulley Used Toyota Crank Pulley Bearing for Aux Pulley 2jz SRD Boost Solenoid Bracket Boost controller solenoid K&N Filter for IAVC Cam Breather Hose and covering Bosch Knock sensor for syvecs Thermal Sleeve and heat covering SRD Heater Matric Hose Kit Syvecs Pressure sensor loom and Pug Vac Hoses Toyota 5sp Flywheel Bolts Aux Belt 6PK1938 Stock 2jz Toyota PS Air Valve Precision V Band Clamp SRD E85 Safe Fuel system Lines and fittings -8 Feed, Billet -8 high flow fuel filter, Y Piece, Twin -6 Feeds to rail, -6 return from rail to FPR, -6 Return to tank. Billet roll over valve and all Teflon lines with fittings Air con Service SH77mm Hose joiner Black Horn Hi note Horn low note Walbro 450/485 in tank filter Bonnet cables and catches Fuel pump relay and plug SH100mm Hose joiner All bumper fixings, bars, seal and number plate surround HKS Blanking cap pair 10mm Tyre fitting and balancing Toyota uk spec read disc Full uk spec brake rebuild includes all parts paint and stickers Brake pads UK spec front Brake pads UK spec rear Battery for supra Used Toyota master brake cylinder 2 port Prestone AF Premix Millers CRO10w40 Running Oil brake lines an fittings for master cylider Toyota Diff Bush 1 bolt R453 Fog light Bulb Toyota Rear brake pipe T Piece non ABS Toyota Front to B brake pipe non ABS Toyota Rear brake pipe NS no ABS Toyota rear brake pipe OS no ABS Toyota Read brake pipe clamp SRD Alloy Expansion Tank Toyota UK Spec shim kit front Toyota UK Spec shim kit rear Toyota brake pins front Toyota brake pins Rear Toyota UK Spec anti rattle spring rear Clear side indicators Toyota UK spec AR Spring front Number plate Large JAP Bride RO Rail JZA80 L Bride RO Rail JZA80 R Toyota Washer Jets LL Remote locking Used Wiper arm set Bosch 21"wiper with spoiler Bosch 20" wiper Toyota over flow cap assembly Toyota bonnet seal rear clip Dipped and main bulbs Black car matts Used Toyota ECU Cover Petrol Used Drivers Door Card Used Toyota Brake light switch Parts for rear fog light MOT TEST Syvecs 3.5 bar to NPT Toyota Rear brake pipe T Piece non ABS SRD Toucan Mount Plate Toucan Display Toyota Oil Pump OEM Cleveite bearing set 2jz Toyota FMS Toyota oil strainer gasket Toyota oil filter large DEI T4 Titiaum heat shield Millers CFS 10w60NT + Running in mineral oil Restone AF Premix Harness adaptor Toyota PC2-174 Mapping & Dyno time Toyota Boot rubber stop Toyota Boot rubber screws Toyota 6sp shifter Cradle Toyota 6sp shifter lower bush Toyota 6sp shifter lower bush O ring Toyota 6sp shifter seat Millers CFS 10w60 5Ltr Toyota Oil filter large Toyota Drain plug gasket Toyota V160 Cover NS Toyota V160 Cover OS MOT TEST 2JZ head with Crawler Cams HKS Twin plate clutch - - - Updated - - - Sold. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted January 27, 2019 Author Share Posted January 27, 2019 reserved for pictures [ATTACH=CONFIG]230553[/ATTACH] [ATTACH=CONFIG]230554[/ATTACH] [ATTACH=CONFIG]230555[/ATTACH] [ATTACH=CONFIG]230556[/ATTACH] [ATTACH=CONFIG]230557[/ATTACH] Some [pictures wouldn't upload so here are the URL links [ATTACH=CONFIG]230919[/ATTACH] [ATTACH=CONFIG]230920[/ATTACH] [ATTACH=CONFIG]230921[/ATTACH] [ATTACH=CONFIG]230922[/ATTACH] [ATTACH=CONFIG]230923[/ATTACH] [ATTACH=CONFIG]230924[/ATTACH] [ATTACH=CONFIG]230925[/ATTACH] [ATTACH=CONFIG]230926[/ATTACH] Link to comment Share on other sites More sharing options...
drift_bear Posted January 27, 2019 Share Posted January 27, 2019 No way! Didn't think you would actually go through with this dude Being 25 i would offer it up to the US market for that price as it would be snapped up i think Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted January 27, 2019 Author Share Posted January 27, 2019 No way! Didn't think you would actually go through with this dude Being 25 i would offer it up to the US market for that price as it would be snapped up i think Not sure how to offer it to the us market, and yeah not a easy decision but I would like to free up the money in this to buy a property as they are so expensive and see what other cars to buy. No rush to sell though. Link to comment Share on other sites More sharing options...
AC93 Posted January 27, 2019 Share Posted January 27, 2019 I know the feeling, in March I'll be selling my bone stock TT to fund a house purchase.. wish I didn't have to, but it's the only way Link to comment Share on other sites More sharing options...
MRX Posted January 27, 2019 Share Posted January 27, 2019 Shame you have to sell mate as i know how much has gone in to this build, but good luck with the sale! Link to comment Share on other sites More sharing options...
FAMILY MAN Posted January 27, 2019 Share Posted January 27, 2019 Good luck with the sale , car is a cracker great build Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted January 31, 2019 Author Share Posted January 31, 2019 Good luck with the sale , car is a cracker great build Cheers dude. Link to comment Share on other sites More sharing options...
Style Posted February 1, 2019 Share Posted February 1, 2019 Not sure how to offer it to the us market, and yeah not a easy decision but I would like to free up the money in this to buy a property as they are so expensive and see what other cars to buy. No rush to sell though. JM Imports should be able to export the car for you. They may even be able to advertise it. If you're on Instagram or something then that might be a good place to start with just reaching out to US followers Link to comment Share on other sites More sharing options...
bayside_supra Posted February 2, 2019 Share Posted February 2, 2019 No way! You spent years finding a car and getting it to this stage. Big shame mate. Glws. Being that our cars are quite similar spec, I will be very interested to see what this fetches Link to comment Share on other sites More sharing options...
evinX Posted February 3, 2019 Share Posted February 3, 2019 WOW. Shocker to say the least. After all that graft! Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted February 5, 2019 Author Share Posted February 5, 2019 No way! You spent years finding a car and getting it to this stage. Big shame mate. Glws. Being that our cars are quite similar spec, I will be very interested to see what this fetches /QUOTE] WOW. Shocker to say the least. After all that graft! Yeah its not a light decision, in no rush to sell but at the same time I'd like to have the money to now go into a property. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted February 12, 2019 Author Share Posted February 12, 2019 Fresh MOT no advisory's, now just having service etc so will be back with me hopefully at the weekend. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted February 20, 2019 Author Share Posted February 20, 2019 Added pictures taken from underneath when it was having its service at SRD. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted March 8, 2019 Author Share Posted March 8, 2019 Still for sale. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted April 10, 2019 Author Share Posted April 10, 2019 Bump Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted April 22, 2019 Author Share Posted April 22, 2019 Car has been sold. A sad day but its gone to someone who is going to look after her, has friends on the forum and it will have some big changes planned for her. I look forward to seeing the changes made. I will eventually be back in a supra or at least get a shell and build one back up but for now I will be going for property and then I will look into another car and look into getting another supra. Link to comment Share on other sites More sharing options...
supra_ufo Posted April 23, 2019 Share Posted April 23, 2019 nice to meet you ant. The SUP was lovely on the way back, didnt give any issues. sounds were amazing. Sohail is in love and it will defo be looked after. I'll get him to register and sign up on here. cheers pal. Link to comment Share on other sites More sharing options...
