G.R.A.M.S active spoiler lip
Sandesupra
I've seen their carbon fibre products in person. make sure the top coat / laquer has been done properly and then if it's not, get ready to argue that it isn't and be told that they did it properly lol
/QUOTE]
Hehe[emoji85] I’ve read about their customer service[emoji23] and the quality... but as it’s the lower lip I’m guessing it’s going to get pounded anyway[emoji23]
But hoping it’s a straight forward fit...
Sent from my iPhone using Tapatalk
Do you have an active spoiler setup already? If not it's not very straight forward. You will have to make up your own brackets to fix it on the OEM lip. There is not much space though.
I did it successfully using the grams fiberglass one and it was great really, but got destroyed when i hit a rabbit.. I will try to see if I have any pics.
Edit:
Love this photo. [emoji7] https://jza80.mkivsupra.net/imports/2018/06/157.jpg
/QUOTE]
Edited by nolizma (see edit history)
Do you have pictures of the brackets by any chance?
/QUOTE]I had a look but can't find any. Sorry.
What I did is I cut some sort of support plates to take the load as the return lip at the bottom edge of the oem lip (not active) is very small and I was afraid that held on by screws only would tear it apart.
This will make more sense if you have a look at your oem lip.
Another thing to note is that the oem lip is very flexible and the shape will change off the car, so maybe it will make more sense to take off the hole bumper when doing this so you will have something more solid to work with.
I hope this helps.
Sent from my F3211 using Tapatalk
