james_cbr Posted January 23, 2019 Share Posted January 23, 2019 hi I had a na facelift car witch I swapped out for an early non vvti tt engine and 6 speed box recently fitted a facelift tt engine bay loom but the new loom has a 4 pin connector where it would plug in to the air con pressure sensor and I have a 2 pin sensor can I pull pins and fit my old 2 pin plug and connect up or do I have to fined a 4 pin plug ? Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted January 24, 2019 Share Posted January 24, 2019 I would rather change the sensor mate. I am sure the other wires are there for a reason. It should be ground, supply, pressure signal and something else? Guaranteed the sensor must have a way of telling the ECU to maintain higher rpm when its engaged but then again I am unsure. Quote Link to comment Share on other sites More sharing options...
