Noz Posted January 23, 2019 Share Posted January 23, 2019 So, I've always wanted a rear fog in my rear lights. Currently, I have no rear fog. I know Heckler created PCB that can direct an switch to turn on a set of rear lights as fogs for this, has anyone ever made a circuit that tells you when a rear light is actually not working? Not the OEM one that just says light out, but a specific WHICH bulb or even brake lights (does the OEM setup even consider the brake lights)? I've created a bought that controls various front LED / Halo, I was looking to do something for the rear of the car just to tell me if any lights are. Using micro processor Arduino Mega. Some may say, why bother, but one of my goals in my build is to modernise it in hundreds of ways electronically and have it feel like a modern car technically. LED door handles (fading on), rear parking sensors, updated interior electronics, front lights startup function (I've halo & LED sidelights). Turning fog light when below 40mph and sharp turn as per the VAG cars is also on my radar! Hoping to setup my aircup with a nice touchscreen for front/front+rear lifts. Anyway, I'm side tracking LOL! Quote Link to comment Share on other sites More sharing options...
Ric Posted January 23, 2019 Share Posted January 23, 2019 Would be a good idea if it can be easily integrated. If you need to re-route all the wiring for the lights to that circuit board. Could be off putting. Quote Link to comment Share on other sites More sharing options...
Burna Posted January 24, 2019 Share Posted January 24, 2019 That's a lot of hacking into a stock loom for all that lot Quote Link to comment Share on other sites More sharing options...
Noz Posted January 24, 2019 Author Share Posted January 24, 2019 Just cut each bulb and attach to screw pin connector. Easy. If I design the circuit board it'll all easily be located in the rear and just sit between each 12v input. 8 wires. Quote Link to comment Share on other sites More sharing options...
Herb Posted January 25, 2019 Share Posted January 25, 2019 Interesting plan! Quote Link to comment Share on other sites More sharing options...
Al Massey Posted January 25, 2019 Share Posted January 25, 2019 Sounds like a good idea. I guess it depends on the installation and guessing this could work on any car really? Quote Link to comment Share on other sites More sharing options...
nolizma Posted January 25, 2019 Share Posted January 25, 2019 The oem system considers brake lights. The same warning light for any of the rear bulbs. I think its sufficient. Quote Link to comment Share on other sites More sharing options...
Noz Posted January 26, 2019 Author Share Posted January 26, 2019 The oem system also comes with bumpers and wheels. I suppose no one needs ever change them either LOL.. plus I mean look at the supra electrics vs brand new cars. Why did they ever upgrade anything. Most items are sufficient. It just depends how you want to modernise your car. Or leave it as it is. Yeah Al. Any car really. I'll probably make two. Sell one just for fun and fit one to mine. Just for the hell of it. Quote Link to comment Share on other sites More sharing options...
nolizma Posted January 26, 2019 Share Posted January 26, 2019 Sorry didn't mean to sound discouraging, just tried to answer your question. Quote Link to comment Share on other sites More sharing options...
Noz Posted January 27, 2019 Author Share Posted January 27, 2019 Just a difference of opinion man it's no issue Quote Link to comment Share on other sites More sharing options...
Al Massey Posted January 28, 2019 Share Posted January 28, 2019 Yeah Al. Any car really. I'll probably make two. Sell one just for fun and fit one to mine. Just for the hell of it. Could be a good option for other cars that dont have a warning system for broken lights. If cost effective, could be viable Quote Link to comment Share on other sites More sharing options...
Ric Posted January 28, 2019 Share Posted January 28, 2019 a true plug and play option with supra looms etc already attached would be good. But would push the cost up quite a lot id imagine. Quote Link to comment Share on other sites More sharing options...
Noz Posted January 28, 2019 Author Share Posted January 28, 2019 (edited) Could be a good option for other cars that dont have a warning system for broken lights. If cost effective, could be viable Would be cheap to be fair. Most bits are easily found. a true plug and play option with supra looms etc already attached would be good. But would push the cost up quite a lot id imagine. Not if you can easier buy the connectors. To be honest, be easier than cutting. Wonder what connectors they use? Will have a Google in a moment. I've tried looking, not that easy for the plug. I think I'll just install some multi pin connectors either end, so I can install and disconnect. Too much pain to try and source the impossible. As long as it's removal easy enough, that's the main thing I suppose! Edited January 28, 2019 by Noz (see edit history) Quote Link to comment Share on other sites More sharing options...
