What to do / check first
tayr
Hi All,
So i have my Supra coming over from Japan in March.
Things which are being done on arrival is;
Oil and Filter Change
All necessary conversions
Full Cavity underseal and protection.
What are other things that i should look to be doing first of all?
I'm thinking brake fluid but not sure what else
i have read maybe the crank pulley is a good one to do?
I did try the search feature but not entirely sure what i should be typing in to find the answer.
Presumably its being MOTd by the importer?
Things I would check:
Obvious damage and poor repairs (masking lines near windows are an indicator)
Wipers
All lights / mirrors (is power)
Air con
Seat belts
All other interior functions
All fluid levels, filters and condition
Check engine bay for leaks and visual damage
Check aux belt
Remove plastic plug cover - check condition of plugs and cam belt
Crank pulley damper rubber
Engine and transmission mounts (facelift mounts fail)
Get it up on a ramp, inspect brakes, wheels/tyres, suspension, wheel bearings etc. Tyre wear should indicate any serious alignment and tracking issues. Check all lines, transmission and lower engine area for leaks and damage.
Check battery and starter function on startup, and look for any exhaust smoke. Make sure the car engages gear and pulls away smoothly. Listen for any unusual sounds, steering pulling, vibrations through the wheel or car etc. Check gauges, ensure car is boosting correctly if its a turbo.
Consider taking a friendly mechanic if you're not 100% on the things you should be looking for. :)
Hiya mine when I got it from Japan was a grade 4 but it needed a full respray! I changed everything and it only had 23k on the clock and just had a cambelt change! The fuel line had been checked but I hadn't changed it! Please keep a fire extinguisher on board as I do now! And please check everyrhing!
I was gutted! Luckily enough I found a gz areotop from keron! So I'm back enjoying supra life! Hope you enjoy it matey when she turns up
Inspect the car on a ramp first as noted above
Minimum I would
re-Torque subframe bolts
T Belt changed for piece of mind
Valve cover seals , they are prone to leak, visually easy to see; good chance to inspect the cams, head
Cam breather pipes ( would get a set in anyway, nice to have in the toolbox)
OE Fuel Filter
Oil filter
Toyota Red Coolant, replace any coolant pipes if they are cracked and perished
Brake fluid (Dependent on condition)
Brake pads (Dependent on condition)
Spark Plugs
Inspect Coil pack clips, prone to fatigue with heat over the years, I would replace , inexpensive ; save you chasing boost issues later
Inspect Coil packs for cracks
OE Gear box Fluid
Rear Differential Fluid
Powersteering Fluid
If you are doing the Tbelt or crank pulley , I would do both together with Cam seals
Nice to have
New Oil pump , you can inspect the big ends when the sump is off
Water pump
Edited by Jellybean (see edit history)
What was wrong with the Fuel line , corroded ?
All fluids, crank pulley is on condition really, but won't hurt to change it if you want to.
Some people change the tyres too as they aren't E marked, but I still run the Toyo's my Supra arrived on
Wipers
Air con
Seat belts
Check aux belt
Minimum I would
OE Fuel Filter
Oil filter
Spark Plugs
OE Gear box Fluid
Powersteering Fluid
Nice to have
Water pump
Thank you guys - all the odds and sods clips and seals etc, where do i find all the part numbers for these?
I was hoping to go BPU quite soon after it arrives but i'd rather make sure car is mechanically sound first
