V160 gear selector rod play
Swampy442
Building a project Supra with some tasty bits, whilst checking everything over I noticed a lot of play in the gear lever, assumed the nylon cup at the base of the lever.
Replaced that with a new lever assembly but the slop still there. The gears all engage lovely its just the movement whilst its in gear.
There seems to be a good amount of vertical play in the input arm, does anyone know if the pin wears or the actual arm itself?
  • 4 months later...
No Chris, the selector shaft is fine, the hole for the locating pin is fine too, its the extension hole thats ovalised
Swampy, just double checking, is it gold shaft that you purchased for £30 to fix it?
