Supra VVTi TT engine and body parts
EMPEROR
Looking for the following parts from a Supra VVTi TT engine:
- Facelift engine mounts
- Facelift Airbag ECU (89170-14041)
- VVTi Control valve (15330-46010 or 15330-46011)
- Alternator (from Auto Supra - 27060-46120 or 27060-46111)
- Power steering pump
- A/C compressor (88320-14600)
- A/C condenser (88460-14310)
- Decent aftermarket (or eventually stock) cat back exhaust system
- Heated seats switch + wiring
- Headlights washer switch (from UK/EU Supra)
- Headlights level switch (from UK/EU Supra)
- Facelift active spoiler switch
- OEM Sub (86150-14160)
- Wiring for the Amp (82166-14081)
- OEM 16 or 17 wheels, doesn't matter if they have tires or not, but the cheaper the better - FOUND
- OEM Amp (86280-14300) - FOUND
- Facelift front bumper (this one is pretty urgent!) - FOUND
- Facelift turn signals and side markers for the front bumper - FOUND
- Facelift active spoiler ECU - FOUND
- Facelift engine mount brackets - FOUND
- complete intake side (manifold, throttle body, injectors + rail, etc) - FOUND
- Starter motor - FOUND
- throttle cable - FOUND
- fan shroud FOUND
- coils - FOUND
- battery holder - FOUND
- Facelift headlights - FOUND
- complete exhaust side (manifold, turbos, pipes, etc) - FOUND
- Tiptronic radiator - FOUND
- Facelift steering wheel airbag - FOUND
- Facelift driver side wing - FOUND
- Both parts shown on the attached pic:
57104-24021 01 05.1993 - MEMBER SUB-ASSY, FRONT CROSS - FOUND
53205-14110 01 05.1993 - SUPPORT SUB-ASSY, RADIATOR, UPPER - FOUND
I live in Germany, but if you don't want to sell abroad, I can give you address in London for the shipping.
I personally prefer multiple parts from one place, but would consider every offer.
Offers here or on PM.
Regards!
Edited by EMPEROR (see edit history)
  • 3 weeks later...
  • 2 weeks later...
Hello mate, I might be able to help with a few bits;
Set of stock 16" wheels with good tyres on
Uprated alternator - 170amp Mechman
Power steering pump
AC condensor
AC compressor but the clutch on the front has burnt out. Can be replaced but hasn't run for a couple of years
Drop me a message if you're interested
  • 3 weeks later...
  • 1 month later...
It's been ages, since I last update here, but due to multiple reasons, the project was "a bit" prolonged.
I am still looking for the parts above.
Car was pretty much toast... but it turned out good in the end. Maybe I should do a project thread at some point...
139167368_739396166682692_2538050826173383608_n.thumb.jpg.06cdf0e83a5a5927bcae8ccb654d6f59.jpg
