Argyle dan Posted December 17, 2018 Share Posted December 17, 2018 For sale is a Syltech IACV for a 2JZ GTE pre vvti. I bought this new around 6 months ago from Australia to fit my link thunder ecu. This is ideal if your struggling for auxiliary outputs as this is a 2 wire valve not the stock 6 or even 4 wire ones. This will only fit the 2JZ GTE. It comes with the adapter plate and gasket but you will need to use the stock rubber check valve and rubber washer, that’s on the standard valve. I was using this on the link but can be used for any other aftermarket ecu ( aem, syvecs,motec, etc). The only reason I’m selling this is that I’ve converted to electronic throttle body so this is no longer required. This cost me £150 to import from Oz so looking for £75 delivered to mainland UK. Any questions feel free to ask. Link to comment Share on other sites More sharing options...
Argyle dan Posted December 20, 2018 Author Share Posted December 20, 2018 Provisional sold. Link to comment Share on other sites More sharing options...
