Dave Posted December 16, 2018 Share Posted December 16, 2018 (edited) http://www.mkivsupra.net/vbb/showthread.php?72588-Code-42-Fix/page3&highlight=code+fix As the title says , I’ve done the 42 fix ( link) this has just started again Anyone else had all these together .stop the car and restart all lights go out but speedo still not working.but they come back on after a few mins. I sliced the pink wire from the plug into the blue red wire .this has worked for a long time now . but others say splice the loom side pink wire into the blue red ,when I did this my my speedo was all over the place. and now I have the same problem again GRRR! Edited December 16, 2018 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
Shane Posted December 16, 2018 Share Posted December 16, 2018 No.1 sensor provides signal for the speedo and odo, its buffered in the odo and then gets back to the ecu after buffering or not if as in your case the pink wire mod is in place and the simple buffer circuit is bypassed. What I have discovered is that the reason it goes back to the ecu was a fail safe mechanism built in by Mr T so if the speed sensor No.2 fails, instead of leaving you stranded the ecu gets enough info from No1 to get you home. So with that in mind, if the ecu doesn't see what it's expecting from No1 it wants you to know and you get code 42. As you have no speedo, I would be looking at the output from No1 sensor first. HTH Quote Link to comment Share on other sites More sharing options...
Dave Posted December 17, 2018 Author Share Posted December 17, 2018 No.1 sensor provides signal for the speedo and odo, its buffered in the odo and then gets back to the ecu after buffering or not if as in your case the pink wire mod is in place and the simple buffer circuit is bypassed. What I have discovered is that the reason it goes back to the ecu was a fail safe mechanism built in by Mr T so if the speed sensor No.2 fails, instead of leaving you stranded the ecu gets enough info from No1 to get you home. So with that in mind, if the ecu doesn't see what it's expecting from No1 it wants you to know and you get code 42. As you have no speedo, I would be looking at the output from No1 sensor first. HTH cheers shane am going to rewire the mod maybe after all this time its come loose ,it all works for a while then speedo stops and the mentioned lights come on .this is what happened before i did the mod .in 2004 Quote Link to comment Share on other sites More sharing options...
