Wangan Supra 2.0 Build @SRD
Chingy
  • Replies 83
Posted Images
Chingy. Can you find out if they will sell me that intake fitting with the banjo for the std 2jzgte intake? I see it in the 4th photo where the trays are labelled intake.
I am still in need of it and agents don't have it mate.
From the work they have conducted and how the blue printed the bottom end of yours, I would even pay stupid money for work like that but I am a qualified technician so I will be able to conduct the same one day soon. Just needta get me self a small vegetable counter scale.
Lovely progress. Keep it up.
Sweet! This is how I except an engine builder to work.
Can not speak highly enough of the craftsmanship at SRD
its a shame its not that simple when it hits your wallet :D
Keep telling myself it’s an investment :D
Wow Colin.
That looks awesome :)
Thanks Luc, I see yours is coming along very nicely
Thanks for the appreciation...... if you are still after that fitting I can ask Lee when I next speak to him, no problems, let me know
  • 1 month later...
Before I start I must say, If Carlsberg did tuning shops I can confidently say they would not be nearly as good as SRD Tuning....... check this out.
So after splitting the engine for all the above we moved to the turbo side of things.
Now the car has an uber rare “Trust” factory twin turbo kit. These were only available for two years in Japan being extremely expensive which which lead to it being discontinued and replaced by the much more affordable GReddy T78 & T88 kits and then totally eclipsed by the HKS GT2835 kit came out in 1999 or 2000.
Now modern big singles are much more efficient but I have always been a fan of big twins and this set up works really well. However nearly 20yrs old I wanted to keep the twin set up but with a more modern design on the existing proven manifold.
This twin manifold used GReddy forged ridged flanges and a JUN exhaust flange plate with a single waste gate made from steel.
The obvious upgrade would be to remanufacture the existing manifold in 304 stainless steel in a thicker 3mm for increased strength and heat resistance.
However for a one of, SRD commissioned an all mandrel bent (rather than cast elbow) 2mm wall manifold based on the original with an improved waste gate collector design. All made from the exotic 321 stainless steel, which is a titanium stabilised stainless steel. 321 is lighter and stronger than 304.....at 2mm its the equivalent of 4mm 304. It also maintains more strength and toughness at extreme temperatures.
A few pics of the old rare and now new one off SRD manifold.
  • 4 weeks later...
  • 1 month later...
  • 2 weeks later...
Engine all successful fired up, initial 100miles dyno running in, all new software down loaded to replace the out of date early version. Map is being built due to the original old map being somewhat far from desired fuelling goals due to the fresh engine and new manifold.
Then next...... oil change, 400mile road running in to bed the new carbon clutch before further final remap.
As alway SRD plug https://www.srdtuning.com 01444 616771
Lovely build congrats. What did you use to polish up your rims they look amazing and mine looked similar to your condition before you polished them.
Yeah they always come up nice the old CCWs, I used Meguiars NXT Metal polish with various polishing polishing drill bits and they several coats of Poor Boys Wheel Sealent
Looking stunning as always! Perfect!
Thanks buddy, much appreciated
  • 4 weeks later...
This is the end of my build thread thank you for all those who followed, Pics to follow now the car is now back at home.
HUGE thanks to SRD and all the team, if you are thinking of having works done professionally I can not recommend them highly enough - GET YOU CAR BOOKED IN!
The WANGAN now 2.0 is a completely different car to when I first collected.
Spec below in what I can only describe as my perfect wish list resulting in a car when horse power feels like torque.
Supra JZA80- 1995- 3100cc,
967(BHP) / 944(N.m) - 211mph
Wangan Originally Built by Front Row Itoh Engineering (Japan) 1998
Wangan 2.0 Improved & Fully Blueprinted by SRD 2019
Maintained by Lee @ Supra Racing Developments
Engine Spec
3.1 Litre 2JZ (built by Front Row Itoh Engineering Japan 1998 & SRD Blueprinted in 2019)
8500 RPM limit
HKS 87mm Forged pistons
HKS Titanium Piston Rings (2019)
Carrillo HD rods with CARR Bolts (2019)
SRD Stage 3 Head Port and Polish (2019)
Full head refresh with Toyota components (2019)
Brian Crower valve springs
Brian Crower Titanium retainers
New Stem Seals (2019)
New Cam Seals (2019)
ARP L19 Head bolts (2019)
ARP Main bolts (2019)
HKS 272 Camshafts
NGK racing plugs (2019)
Gates Cam Belt (2019)
Complete Toyota Gasket Kit (2019)
Toyota Head Gasket (2019)
Toyota Oil Pump (2019)
Toyota Oil Filter (2019)
Toyota Squirters (2019)
Toyota Water Pump (2019)
Toyota Freeze Plugs (2019)
Clevite S Series Main & Big End Bearings/ Thrust Washers (2019)
Titan Carbon spark plug cover
Titan adjustable cam pulleys
Chrome cam covers
-12 breather lines
Unorthodox Racing lightened pulley set
Power House Racing Pulley (2019)
TTC Performance Billet Aluminium Upper Shock Arm (2019)
TTC Performance Idler Pulley (2019)
Fluidampr Botom Pulley (2019)
TRD Engine mounts
TRD Oil filler cap
ARC Carbon radiator plate
Blitz Rad Cap (2019)
SRD Alloy radiator with custom -24 fitting
Aeroquip braded top radiator hose
SRD Polished alloy header tank
SRD Polished billet water neck
SRD Twin Kenlowe electric fans
SRD Heater Hose Kit (2019)
SRD 180AMP Polished Alternator (2019)
TRD Thermostat
HKS Oil cooler
Millers CFS 10w60 Oil
SRD custom engine boxes/heat shields painted 202 black
Polished fuse box cover with Supra logo etched
Battery to boot relocation
Carbon Fibre Battery Box (2019)
Carbon Fibre Intercooler Plate
Custom Fabrication & Brackets
Castrol Gearbox fluids
Turbocharger & Induction
Two GReddy TD05 turbos (new internals 2015)
Twin K&N air filters
Braided Oil feed and Return Lines
Custom suction pipes
Titanium turbo blankets (2019)
GReddy Wastegate
Custom Screamer pipe
GReddy BOV
GReddy custom made Stainless Steel 321 manifold (2019)
Front Row custom downpipes
Front Row custom 3.5” exhaust
Hypertune Polished Plenum
90mm throttle body
Custom Large front mounted intercooler
Custom Intercooler piping
Fuelling, Timing & ECU
Syvecs S6 ECU
8 Maps (2019)
Ethanol Fuel Flex Sensor
Launch control
ASNU 1100cc Injectors
Hypertune twin feed fuel rail
Aftermarket front pipes
Earls lines and connectors
Aeromotive FPR
Aeromotive Filter (2019)
Twin Walbro 485lph fuel pumps
Teflon fuel lines -8 feed -6 return
Drivetrain
Brand new unused V161 6 speed Getrag gearbox (2016)
RPS 3.0 Triple Carbon Billet Clutch (2019)
RPS Billet Flywheel (2019)
Goodrich braided clutch line
TRD LSD Large Case Diff
SRD Clutch Master Cylinder Heater Protector (2019)
Motrul RBF660 Clutch Fluid (2019)
Suspension & Chassis
Tein Flex Coilovers
EDFC in car controller
ARC Front anti roll bar
Cusco Rear Strutt Brace
Interior
TRD Steering wheel
TRD 10,000 RPM Tachometer
TRD 320 km/hour Speedometer
TRD Factory Temperature
Recaro Speed Seats
Bride RO seat rails
DC Automotive floor mats
Toucan touch screen display
Kenwood multimedia head unit
Kenwood Front Components
Kenwood Rear Speakers
Foam Fire Extinguishers
Security
GPS Traker x2
CAT 1 Alarm & Immobiliser
Exterior
Stock body with rear arch flare
RMM Polyurethane front lip
Facelift headlights
Facelift rear lights
Custom DRL/side lights
Smoked side repeaters
Custom flip front number plate
SRD Alloy rear diffuser
SRD Alloy engine undertray
Custom alloy fuel line undertray
Custom alloy bonnet
Stainless gas bonnet lifters
Custom bonnet hinges
Windows lightly tinted
Brakes
K-Sports 356mm 8 pot Front Brakes
UK Spec Rear Brakes
EBC yellow stuff pads
Stainmesh brake lines
Millers 300+ Brake fluid
Wheels & Tyres
CCW Classics wheels (Drag Pack) 10”x18” Front and 11.5”x17” Rear
Toyo T1 front tyres (285/30/18)
Toyo R888 rear tyres (315/35/17)
10mm Rear wheel spacers
ARP rear wheel studs
Edited by Chingy (see edit history)
