herbiemercman Posted November 29, 2018 Share Posted November 29, 2018 Hi Guys, Some questions for the high tech members of the club: 1. Does the engine temperature sender to the ECU supplying fueling info come from the engine water temp or the oil temp? 2. Does the "Greedy E -manage" unit replace the stock ECU or just piggy back onto it ? 3. Does anyone know where diagnostic software would be available for the Mk4 ? Many thanks. Herbie. Link to comment Share on other sites More sharing options...
walkerstrider Posted November 29, 2018 Share Posted November 29, 2018 Hi mate The emanage is just a piggy back as I run the same. As for the first question I think it uses both but could be wrong. As for diagnostics the only thing I can think of is the tsrm app. What's your issue? Link to comment Share on other sites More sharing options...
Mike2JZ Posted November 29, 2018 Share Posted November 29, 2018 Hi Guys, Some questions for the high tech members of the club: 1. Does the engine temperature sender to the ECU supplying fueling info come from the engine water temp or the oil temp? 2. Does the "Greedy E -manage" unit replace the stock ECU or just piggy back onto it ? 3. Does anyone know where diagnostic software would be available for the Mk4 ? Many thanks. Herbie. Ok so first of all, the Emanage is a piggyback. This means that you run the original Supra ECU, then wire in the emanage to run in conjunction with stock ECU. The emanage recieves certain signals relating to fuel/ignition/manifold pressure etc, then outputs a different value back to the main ECU. This is known as signal "fudging". There are also a number of signals like water temp, crank angle, rpm etc that the emanage gets wired to but it only reads these signals. With regards to temperature sensor, the eManage can be wired to read the factory water temperature sensor, or use it's own independent sensor. Assuming you have a problem with your factory water temp sensor, it will affect both the stock ECU & piggyback. The factory ECU however does not use an oil temperature sensor, so it does not care about this. As a result neither will the eManage If you are using an emanage blue, you can find software and instructions here If you are using emanage ultimate you can find software and instructions here I think Whifbitz have a branch somewhat near you. They have loads of experience setting up NA-T supra's on emanage. No doubt they can help you if you get stuck. Link to comment Share on other sites More sharing options...
WayneW Posted November 29, 2018 Share Posted November 29, 2018 I got a Greddy Emanage for sale if you want Great Piggypack this ! Link to comment Share on other sites More sharing options...
herbiemercman Posted November 30, 2018 Author Share Posted November 30, 2018 (edited) Hi Guys, Many thanks for the info, especially Mike, great technical reply. Walkerstrider, i will look at the TSRM app, thank you. The issue is: http://www.mkivsupra.net/vbb/showthread.php?351382-MISSFIRING-amp-HOT-OIL-TEMP-mK4-NAT WayneW, i hope i do not need one, but thanks anyway. Herbie. Edited November 30, 2018 by herbiemercman (see edit history) Link to comment Share on other sites More sharing options...
