New ASNU 1100cc Top Feed Injectors (ideal for NA-T)
Parm_93
Hi all,
Brand new set of 6 ASNU injectors brought from Whifbitz a little while back. Still boxed and unused.
These are plug and play for the NA, so for the NA-T guys. They will also work with TT but you’ll need to have a 11mm top feed fuel rail and different injector seats if you are using stock intake manifold. If you have a 14mm top feed fuel rail you will need larger top hats. I have a quote from Whifbitz on these.
Will work perfectly fine at lower boost when mapped correctly, entry level NA-T or single turbo, up to around 800-900bhp if not more, so there is plenty of room for future power increases without having to upgrade injectors again.
Link to product; http://www.garagewhifbitz.co.uk/toyota/supra/fuel-parts/asnu-performance-injectors-2jzge.html
SOLD
Thanks,
Parm
Just had a quick read on the link and it seems these aren't e85 compatible right?
Good question! I just got this from the ASNU website, but I would PM Paul and ask him to confirm this.
ASNU Fuels Disclaimer
ASNU fuel systems and injectors are designed to be used in conjunction with standard grades of road-pump fuels, and certain race fuels with lubricant and corrosion packs (please enquire for details of tested and compatible race fuels).
The use of pure Ethanol, Methanol or other chemicals mixed in combination with standard pump gas or race fuels is not advised and will invalidate any warranty on all of our systems. Fuels with more than 50% ethanol, even with lubricants, will greatly accelerate wear and shorten system life as well as reducing the service life on any filters.
Our products are compatible with certain methanol blends containing an appropriate lubricant pack and E85 for race or drag events. When used with fuels that have Ethanol contents over 50% or fuels with a methanol content, the fuel system must be drained and flushed between events to prevent irreversible damage.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
