Orchestra of Whistling?
Scoboblio
Since the temperature has started dropping now I've noticed a difference in the sounds my turbos are making in the cold. I've got used to the usual whistling noise made by no1 under even the slightest of boost, but recently there seems to be at least another 2 whistles joining in :conf:
It's really hard to explain but the other noise seems to be coming more from the passenger side area of the engine side than from no1 itself, and is a slightly higher pitch.
Being an auto it's hard to check exactly where it's coming from as I don't believe the tubbies will spool at a standstill.
It ONLY does this in very cold weather.
There certainly seems to be nothing wrong with the car, both turbos spool quickly, boost is slightly higher due to the colder air, and the car goes like a rocket :)
Any ideas?
My 'baby' turbo seems to be whistling louder and at the drop of a hat too.
Only started when the weather jsut suddenly cooled about 10 days back. I assume it's whistling away in contentment at the temp drop.
Car goes like a rocket too. The second turbo coming online is really noticable now and actually seems to kick more. I'm now beginning to see how it could cause people to lose the back end.
I'm still driving like an old lady though!
