facebook virus
peter richards
If it shows again, try using private browsing. It will not load any cached page data and should not load that message either (unless there is something else on your computer)
I’d also recommend running Malwarebytes to scan your computer and help clear any potential threats
You should check to see if your browser or bookmarks have been hacked. Easily done by copying and pasting the ip address detailed below into your browser bar and hitting return. If it lands on the FB page with no strange messages then you probably have had a bookmark hack. If it ends up with the same strange message then use the ip address in an alternative browser and see what happens. If its OK in an alternative browser then you'd be best uninstalling and reinstalling your preferred browser.
FB ip address is 31.13.90.36
