Jellybean Posted November 3, 2018 Share Posted November 3, 2018 To name a few, Plazmaman Hypertune CPC Sleeper designs The issue with after market intakes is the length of the inlet runners , longer runner favours low RPM torque versus a shorter runner , higher rpm performance (not ideal for the road) I know we have to compromise , most of us go with an aftermarket intake to trick out the engine bay at the expense of low end torque I have two options CPC Carbon intake OE intake , vapor blasted to tidy her up Questions For members with an aftermarket intake , would you retain the OE intake if you had to do it again Is any of the aftermarket intakes , from quality perspective; hands down better than the rest? Does any aftermarket intake , lend itself to more low than torque versus others? Link to comment Share on other sites More sharing options...
Dnk Posted November 3, 2018 Share Posted November 3, 2018 I'd get the OE one and spend a chunk of time removing all the casting lines and imperfections then have it dipped Link to comment Share on other sites More sharing options...
Jellybean Posted November 3, 2018 Author Share Posted November 3, 2018 One of the RB25 guys got his intake vapor blasted After further research , I will keep the OE intake ; might be worth putting the cash towards DBW Link to comment Share on other sites More sharing options...
Dnk Posted November 3, 2018 Share Posted November 3, 2018 Vapour blasting only gets the part clean, it'll oxidize if left in its natural state Link to comment Share on other sites More sharing options...
Jellybean Posted November 3, 2018 Author Share Posted November 3, 2018 Vapour blasting only gets the part clean, it'll oxidize if left in its natural state What do you recommend? Link to comment Share on other sites More sharing options...
Dnk Posted November 3, 2018 Share Posted November 3, 2018 (edited) What do you recommend? Depends how you want it to look after its been vapour blasted, you could powder coat it, paint it, water transfer print it etc I powder coated mine https://www.vaporblastingequipment.com/wet-blasting/what-wetblasting-guide-vapor-blasting-process Edited November 3, 2018 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted November 3, 2018 Author Share Posted November 3, 2018 I like the natural finish , I just want to clean it up Link to comment Share on other sites More sharing options...
Dnk Posted November 3, 2018 Share Posted November 3, 2018 Mine after i'd removed all the casting lines etc Link to comment Share on other sites More sharing options...
Jellybean Posted November 3, 2018 Author Share Posted November 3, 2018 Very nice! Link to comment Share on other sites More sharing options...
Andrew K Posted November 4, 2018 Share Posted November 4, 2018 My TT Intake Manifold & Throttle body i had bead blasted to get it all looking like new again and keep the natural finish, I was worried about it Oxidizing again soon after but the chap I used to bead blast them said to spray they all with clear lacquer. Seems to have worked as 5 years later and 3 years of being on the car they still look like they did when I first had them done. Link to comment Share on other sites More sharing options...
jim_supra Posted November 4, 2018 Share Posted November 4, 2018 My TT Intake Manifold & Throttle body i had bead blasted to get it all looking like new again and keep the natural finish, I was worried about it Oxidizing again soon after but the chap I used to bead blast them said to spray they all with clear lacquer. Seems to have worked as 5 years later and 3 years of being on the car they still look like they did when I first had them done. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=229735&stc=1&d=1541333244 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=229736&stc=1&d=1541333244 Did your blaster do the work with all the sensors in place? Had most of my aluminium parts done now, Just the throttle body to go which I am about to strip down, but if I don't have to all the better! Link to comment Share on other sites More sharing options...
Andrew K Posted November 4, 2018 Share Posted November 4, 2018 Did your blaster do the work with all the sensors in place? Had most of my aluminium parts done now, Just the throttle body to go which I am about to strip down, but if I don't have to all the better! I did take everything off before it was blasted as I was worried about all the very fine beads getting into all the sensors etc. Link to comment Share on other sites More sharing options...
Hemanhead Posted November 4, 2018 Share Posted November 4, 2018 (edited) Questions For members with an aftermarket intake , would you retain the OE intake if you had to do it again No, I love the look and quality of the product. [*]Is any of the aftermarket intakes , from quality perspective; hands down better than the rest? hard to say as I haven't seen them all, the hypertune for me was the stand out product. Very high quality, the looks and fit and finish are certainly desirable. So desirable in fact after seeing Chingy car in the flesh I had to sell my greddy and buy one. [*]Does any aftermarket intake , lend itself to more low than torque versus others? As you've mentioned already the shorter runners lend themselves to top end gain, but I can't say I've lost any driveability and with a small single turbo you will me making more torque and power over just about all the rev range anyway If this is a budget breaker, definitely stay oem and invest in the best parts possible. But money no object, there's no reason not too. Edited November 4, 2018 by Hemanhead (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted November 4, 2018 Author Share Posted November 4, 2018 Thanks for the replies ANDREW that intake came out stunning Will stick with OE, maybe get a different intake in tge future Will keep the funds in the budget Link to comment Share on other sites More sharing options...
