Boot lid is not fully released!
Doublefacy
Hi,
I just bought supra and got this issue with opening boot lid.
When I pull the lever inside the car, it seems like boot lid is not popping up enough to get through both positions on a latch. If I have someone to pull it up as I pull the lever - it opens fine, but wouldn't on it's own. If I'm all by myself , I can't open boot lid :(
I was wondering if those could boot lid struts that might have lost gas and effectiveness over time, as I understand car has not been used all that much before me buying it. Although boot lid stays up pretty strong once opened.
Are struts the ones responsible to pop it open or could there still be issues with latch being sticky?
I have this, just stuff a cloth or a ball under the lever, then til go open the boot. Remember to remove the cloth/ball before closing the boot.
it not the struts because they aren’t in operation until it’s open open (they are horizontal and neutral for the 2 degrees the lid opens from the lever) I think it’s the cableing that needs tightening from the lever to the catch release
Thank you all, did not expect so many responses in such a short time. Good to see Supra community strong :)
I do have facelift model (2001). Will try to find that How To thread about boot release. Meanwhile will follow advice of stuffing something under lever :)
Just out of curiosity, what makes it pop open then if not struts? Is it rubber seal around the boot? Can't see latch doing it.
Will check cabling and see if latch itself moves freely to fully release boot lid.
I've had the exact same problem.
What did you do to fix it?
As much as I could use key to open boot, which I honestly haven't tried as I'm used to fob on my other car and didn't even think of it. I really want to fix the release from inside.
Didn't had a time to look at it today - will try to run some checks tomorrow.
Well known fault with the face lift
I replaced the blocks with brand new and did nothing
I just use the key or keep lever pulled whilst missis open the boot lol
Same. No change buying new blocks. If I'm carrying something in one hand, I've developed a technique of turn key, lift boot using shoulder under spoiler, remove key, lift boot with hand :clown:
My facelift was the same, my work-around was to wrap the belt around the release to keep it open til i got to the back if i had the car on.
My solution was to get a pre-facelift mechanism which sorted it fine, i didn't replace the blocks or anything else.
