Single install Q's
Jellybean
The factory wastegate VSV controller is the blue VSV as follows:
Assuming you are using a P&P ecu that uses this VSV's wiring for boost control, then you need to cut the plug end off, and wire the two wires to your 3 port boost controller.
It does not matter what the orientation of the wires are
In terms of downpipe, manifold heat control
Is Zircotec, wrapping, both or leave as is, have any implications?
/QUOTE]
I only have my downpipe wrapped and a turbo blanket, never seen any issues with temps or hotstarts.
I suppose the more heat you keep in the system the more potential performance, but it's also alot more heat for the turbo to deal with. Upto you I guess.
