blythmrk Posted October 7, 2018 Share Posted October 7, 2018 This is some info i found The mot history check only goes back to 2005. Still too many questions unanswered though! Link to comment Share on other sites More sharing options...
jim_supra Posted October 7, 2018 Share Posted October 7, 2018 £5k would probably not cover half the missing parts that you can see are missing. Recovering a working a/c would take nearly £2k in parts as the pipework is discontinued so would need fabricating. Then the ABS is absent so are the sensors still there and working, that lot could be another £2k. Then the inter-cooler and oil cooler, there is another £1k+ using non OEM parts. Looks wiring and fuses light. Then if you want an air box with pipework and shrouds and ducting, well thats probably going to be £1k. Then there is the radiator, have to be a non OE one there. Fuses, igniter, charcoal canisters, inter cooler ducting - there is another £2k or so. Front lights, you'd be looking at another £1k there. Front bumper and paint, thats got to be another £1k. Battery and tray, thats not going to cost loads. Looks like no exhaust to, if you need cats and exhaust to get to stock thats minimum £1k spend buying second hand. The engine loom, they are expensive if you can still get them, probably another £500 if you can get one secondhand. This all assumes no labour beyond your own endeavours. Assuming your prices are based on all new parts? With the exception of the second hand oem exhaust you mention of course, (for which your estimate of 1k plus for second hand is waaaay over the mark) To the OP, Decent second hand parts can be gotten for a fraction of the costs mentioned above. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted October 7, 2018 Share Posted October 7, 2018 To the OP, Decent second hand parts can be gotten for a fraction of the costs mentioned above. I agree. I have a fair few of the items listed above for sale if it helps. Drop me a PM if there's bits you need and I'll see what I can do Link to comment Share on other sites More sharing options...
