Best outdoor cover?
Aiden93
Hi everyone,
So I've recently had a Ridox wide arch kit fitted to my supra and had it wrapped, was wondering if anyone knows what the best outdoor covers are and if there are any that would be suitable for the wider body/try not to rub against the wrap as I've had a cover in the past that was a "universal" fitment that ended horribly. Seen some that are made to fit but we're for the standard body without the spoiler.
Thanks in advance 😄
ive got a stormforce ,had a few issues with rubbing and condensation so i make sure mine is as tight as i can get it and its removed once a week washed and waxed.woould give my right testicle for a garage .
- - - Updated - - -
Hi everyone,
Thanks in advance
you should look into having a carcoon
I have a Stormforce, which I believe was considered the best, however I wouldn't use one unless you have a reason why you need a cover (parked under a tree, leaky roof, etc) as it will do more damage than it's worth. If you had a paint finish then you could just buff out the marks it causes, but with a wrap you'll likely cause irreparable damage to it.
