In the morning car starts at 2nd time
Bender
Got this strange problem recently. It not happend every day but looks like more often now at the first turn of key nothing happend all the lights comes on as they should be but car is dead like there was no battery just can hear strange noise onnthe back than i turn again and car starts perfectly normal as it always do. Anybody got idea what that can be ?
Wysłane z mojego SM-G950F przy użyciu Tapatalka
Back of the car or back of the engine? If its the car it could be the fuel pump your hearing which is normal. If its on the engine what kind of sound is it?
Back of the car and i thought so it could be a fuel pump.
That's normal if the starter motor needs reburbing. See first post here: http://www.mkivsupra.net/vbb/showthread.php?70712-Car-reluctant-to-start&highlight=starter+motor
I know that starter motor its 25 year old and cant go forever im just been unlucky lately in the last 2 months i changed (because those parts stop working due to age) following parts diff, radiator, thermostat, water pump, alternator, distributor cap plus rotor arm plus hv leads and now starter motor...well good news is it will be like new under bonnet [emoji23]
One more thing to add whixh can bw helpfull. When my alternator went i was 160 miles from home but as got no choice really so you can imagine when i was almost home all the electrical things stop working (radio gps windows clock etc) and as result of that my battery was dead i put in on the charge over night and it charge back nicely but just to want make sure and have to ask question can a bad battery can do thing like that to ?
A bad battery wouldn't cause the symptoms you described in your first post. The key thing is that your car initially failed to start, then without doing anything, it started fine on the 2nd attempt.
If you have a bad battery you usually get a very slow crank, or just a fast clicking (I guess from the starter motor or associated relays).
