Dragonball Posted October 6, 2005 Author Share Posted October 6, 2005 Email me direct mate please But for the record these are greddy - cant remember the types though Cheers Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 OK Guys - this one has now been dismantled and the parts happily sittting in Jagmans place I will be taking a full inventory next Wednesday of everything and then posting a full list For those interested in stuff then I will come right back to you - but after that it will be posted on ebay and first come...etc (so please dont um and ah...!) All those who have already bought stuff I will endevour to get this all togather for the wend of the week. Anyone who wants it quickly will be able to collect CHeers Quote Link to comment Share on other sites More sharing options...
monkey76364 Posted October 12, 2005 Share Posted October 12, 2005 God love them seats ...but was to far downt he list typical lol Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 This is now available on ebay Most have been allocated where definately bought Loads of parts that are not listed - but will give you an idea Toyota Supra Abs Control Unit Toyota Supra Abs Ecu Toyota Supra Abs Modulator Toyota Supra Abs Pump Toyota Supra Abs Pump Modulator Combined Toyota Supra Abs Sensor Toyota Supra Aerial Toyota Supra Aerial Roof Toyota Supra Air Flow Mass Meter Toyota Supra Air Mass Meter Toyota Supra Air Bag Toyota Supra Air Filter Box Toyota Supra Air Flow Meter Toyota Supra Air Metering Unit Toyota Supra Airbag (roof) Toyota Supra Airbag (seat) Toyota Supra Airbag Ecu Toyota Supra Aircon Compressor Toyota Supra Aircon Pump Toyota Supra Aircon Radiator Toyota Supra Alternator Toyota Supra Anti Roll Bar Toyota Supra Ashtray Toyota Supra Axle Front Toyota Supra Axle Rear Toyota Supra Bell Housing Toyota Supra Body Shell Toyota Supra Bonnet Toyota Supra Bonnet Rams Toyota Supra Boot Lid Toyota Supra Boot Lock And Keys Toyota Supra Brake Calliper Toyota Supra Brake Compensator Valve Toyota Supra Brake Disc Toyota Supra Brake Drum Toyota Supra Brake Master Cylinder Toyota Supra Brake Servo Toyota Supra Brake Slave Cylinder Toyota Supra Bull Bar Front Toyota Supra Bumper Toyota Supra Bumper (front) Toyota Supra Bumper (rear) Toyota Supra Bumper Complete Toyota Supra Bumper Skin Toyota Supra Camshaft Toyota Supra Carburettor Toyota Supra Carpet Boot Toyota Supra Catalytic Converter Toyota Supra Cd Multi Changer Toyota Supra Central Locking Control Unit Toyota Supra Central Locking Motor Toyota Supra Central Locking Pump Toyota Supra Central Locking Solenoid Toyota Supra Centre Console Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 Toyota Supra Clock Toyota Supra Clutch Cable Toyota Supra Clutch Complete Toyota Supra Clutch Master Cylinder Toyota Supra Clutch Pedal Toyota Supra Clutch Plate Toyota Supra Clutch Pressure Plate Toyota Supra Clutch Slave Cylinder Toyota Supra Coil Toyota Supra Coil Ignition Module Combined Toyota Supra Coil Pack Assembly Toyota Supra Coil Spring Toyota Supra Cross Member Toyota Supra Cruise Control Unit Toyota Supra Cv Joint Toyota Supra Cylinder Head Toyota Supra Dashboard Bare Toyota Supra Dashboard Complete Toyota Supra Differential Toyota Supra Distributor Toyota Supra Door Toyota Supra Door Glass Toyota Supra Door Handle Toyota Supra Door Lock Barrel With Key Toyota Supra Door Lock Mechanism Toyota Supra Door Locks And Keys Toyota Supra Door Mirror (electric) Toyota Supra Door Mirror Electric Switch Toyota Supra Door Moulding Toyota Supra Door Trim Toyota Supra Drive Shaft Toyota Supra Ecu Toyota Supra Ecu Central Locking Toyota Supra Ecu Engine Toyota Supra Ecu Fuel Toyota Supra Ecu Gearbox Toyota Supra Electric Aerial Toyota Supra Expansion Tank Toyota Supra Fly Wheel Toyota Supra Fog Lamp Switch Toyota Supra Fog Light Toyota Supra Front Panel Toyota Supra Fuel Control Unit Toyota Supra Fuel Cut Off Unit Toyota Supra Fuel Filler Neck Pipe Toyota Supra Fuel Injection Pump Toyota Supra Fuel Injection Unit Toyota Supra Fuel Line Toyota Supra Fuel Pressure Regulator Toyota Supra Fuel Pump Electrical Toyota Supra Fuel Pump In Tank Toyota Supra Fuel Pump Mechanical Toyota Supra Fuel Sender Unit Toyota Supra Fuel Tank Toyota Supra Fuse Box Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 Toyota Supra Gear Box Ecu Toyota Supra Gear Linkage Toyota Supra Gear Stick Toyota Supra Gearbox Manual Toyota Supra Gearbox Tiptronic Toyota Supra Glove Box Lid Door Toyota Supra Grill Toyota Supra Handbrake Cable Toyota Supra Handbrake Lever Toyota Supra Hard Top Toyota Supra Headlamp Toyota Supra Headlamp Indicator Switch Stal Toyota Supra Headlamp Motor Toyota Supra Headlamp Surround Toyota Supra Headlamp Switch Toyota Supra Headlamp Washer Jet Toyota Supra Headlining Toyota Supra Headrest Toyota Supra Heat Blower Motor Toyota Supra Heat Exchanger Toyota Supra Heat Shield Toyota Supra Heater Control Toyota Supra Heater Fan Motor Toyota Supra Heater Matrix Toyota Supra Heater Motor Toyota Supra High Level Stop Light Lamp Toyota Supra Hood Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 Toyota Supra Horn Toyota Supra Idle Control Valve Toyota Supra Ignition Amplifier Toyota Supra Ignition Barrel And Key Toyota Supra Ignition Coil Toyota Supra Ignition Control Unit Toyota Supra Ignition Ecu Toyota Supra Ignition Module Toyota Supra Ignition Switch Toyota Supra Indicator Headlamp Switch Stal Toyota Supra Indicator Switch Stalk Toyota Supra Indicator Unit Toyota Supra Injection Unit Toyota Supra Injector Toyota Supra Injector Pump Toyota Supra Inlet Manifold Toyota Supra Instrument Body Pod Toyota Supra Intercooler Toyota Supra Interior Light Toyota Supra Lambda Sensor Probe Toyota Supra Landing Slam Body Toyota Supra Leaf Spring Toyota Supra Load Sensing Valve Toyota Supra Luggage Cover Toyota Supra Parcel Shelf Toyota Supra Petrol Fuel Tank Toyota Supra Power Steering Box Toyota Supra Power Steering Hoses Toyota Supra Power Steering Pump Toyota Supra Power Steering Rack Toyota Supra Propshaft Toyota Supra Quarter Panel Toyota Supra Quarterlight Toyota Supra Radiator Toyota Supra Radiator Expansion Tank Toyota Supra Radius Arm Toyota Supra Rear Screen Toyota Supra Rear View Mirror Toyota Supra Relay Unit Toyota Supra Repeater Light Toyota Supra Rev Counter Toyota Supra Rocker Shaft Toyota Supra Roof Section Toyota Supra Screen Washer Bottle Motor Toyota Supra Screen Washer Jet Toyota Supra Seat Belt Toyota Supra Seat Belt Anchor Toyota Supra Seat Belt Pretensioner Toyota Supra Seat Bottom Toyota Supra Servo Unit Toyota Supra Shock Absorber Toyota Supra Side Skirts Toyota Supra Slam Landing Panel Body Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 Toyota Supra Speedo Toyota Supra Speedo Cable Toyota Supra Speedo Clock Toyota Supra Speedo Electric Toyota Supra Speedo Head Toyota Supra Speedo Sensor Toyota Supra Speedo Transducer Toyota Supra Spoiler Toyota Supra Starter Motor Toyota Supra Steering Box Toyota Supra Steering Column Toyota Supra Steering Column Cowling Toyota Supra Steering Coupling Toyota Supra Steering Idler Toyota Supra Steering Lock And Key Toyota Supra Steering Rack Toyota Supra Stepper Motor Toyota Supra Stub Axle Toyota Supra Sub Frame Toyota Supra Suspension Arm Toyota Supra Suspension Leg Toyota Supra Suspension Strut Toyota Supra Tail Gate Hatch Glass Toyota Supra Tail Gate Lock And Keys Toyota Supra Tail Gate Struts Toyota Supra Tail Lamp Lens Toyota Supra Tail Lamp Unit Toyota Supra Tailgate Toyota Supra Thermostat Housing Toyota Supra Tie Rod Toyota Supra Timing Cover Toyota Supra Track Control Arm Toyota Supra Transfer Box Toyota Supra Tyre Toyota Supra Vacuum Pump Toyota Supra Valance Toyota Supra Water Pump Toyota Supra Wheel Arch Moulding Toyota Supra Window Regulator Toyota Supra Window Regulator Mechanism Toyota Supra Window Switch Toyota Supra Window Winder Mechanism Toyota Supra Window Winder Motor Toyota Supra Windscreen Toyota Supra Wing Toyota Supra Wiper Arm Blade Toyota Supra Wiper Linkage Toyota Supra Wiper Motor Toyota Supra Wiper Motor And Linkage Toyota Supra Wiper Switch Stork Toyota Supra Wiring Loom Toyota Supra Wishbone Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted October 12, 2005 Share Posted October 12, 2005 Jesus Paul... You mut have sore fingers.... Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 12, 2005 Author Share Posted October 12, 2005 This lot took me some time to get going to... http://stores.ebay.co.uk/Miami-GT_W0QQssPageNameZl2QQtZkm Should be a load on here for people to choose Pleae let me know if anything has been missed or wrongly priced etc Rgds Quote Link to comment Share on other sites More sharing options...
DamanC Posted October 13, 2005 Share Posted October 13, 2005 Paul - you have PM Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 16, 2005 Author Share Posted October 16, 2005 OK Guys - have given everyone opportunitiy to satisfy everyone and give first opportunty Will be going to catalogue all these parts this week - anyone who wants anything please check out my ebay shop - where loads are listed and priced Any questions please call me First come first served now.... Quote Link to comment Share on other sites More sharing options...
DamanC Posted October 17, 2005 Share Posted October 17, 2005 Thing that have been asked for (such as my bits) are all still secured thou arnt they? Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 18, 2005 Author Share Posted October 18, 2005 Daman - fine mate (sorry missed this post) Will be going up on Friday to catalogue - please let me know of anything else required Best to call me know beforehand - also all bits will be up on my ebay shop soon Quote Link to comment Share on other sites More sharing options...
Dragonball Posted October 25, 2005 Author Share Posted October 25, 2005 Just been down to see this boy at Jagmans (many thank Adam, Chris and Martin for their hospitality!) Have bought back a load of bits etc for peeps to send out etc Loads more too bulky for today's run Please do give me a shout for parts you might want Rgds Paul Quote Link to comment Share on other sites More sharing options...
DamanC Posted October 25, 2005 Share Posted October 25, 2005 you know what im after Paul Quote Link to comment Share on other sites More sharing options...
