Remote locking malfunction
adi2009
Hello! The remote locking system on my car has not been working for a while now, I think the problem is with the key as it cracked (the plastic bit where the buttons are) a while ago. Is there any way I can replace the key and get the remote locking system working like stock?
On pre VVTi models there isn't a pairing button anywhere on the remote module to start the pairing process so maybe they were factory paired by Denso and thats it? Talked with Toyota and they were useless. No one has ever managed to come up with a way to pair remotes to the 93 - 96 Supra as far as I am aware. If you have a later Supra then there are threads on how to do this.
So if you own an early Supra then you will probably find your only options are to get your original setup functioning again or buy and install an aftermarket system.
