1JZ Engine (BC Cams / Pulleys, ATI Dampener) R154 Box, 600hp Clutch, AEM EMS v2, Loom
ChrisPackit
Hi
I have a 1JZ engine package as a full conversion kit available, consisting of;
Low Mileage 1JZ engine, compression results available by Whatsapp (all 150+) with Crower 264 Cams, HKS Pulleys, ATI Crank Dampener, complete with alternator, starter motor, Titan Motorsport Inlet Manifold, Top feed fuel rail with 860cc Siemens Injectors, 100mm throttle body, front sump, new water pump, oil pump, recent timing belt and tensioner, Toyota Ignitor, all coilpacks. Engine made 520hp at 1.4 bar last year.
Comes with R154 gearbox (Soarer version), shifter mechanism, Xtreme Motorsport 600lb/ft clutch kit (12m old), modified Soarer (Manual) propshaft, slave cylinder & flywheel
Also, Engine harness with all required sensors to make it run (Cams, crank, AIT, Water, TPS, AEM 3 bar map sensor etc) and an AEM EMS v2 (Soarer JZZ30 fitment) standalone ECU system.
Designed as a complete drop in package.
Will only sell as complete package at the moment, but may consider splitting if it doesnt sell.
PM or call for a discussion on the whole package etc.
Collection from Manchester / Cheshire area.
£4995.00
Thanks
Chris
07917 730525
