kgctim Posted September 9, 2018 Share Posted September 9, 2018 '93 TT/RHD GZ Supra. I'm going to pull my intake manifold off soon to clean it and freshen up the bits, thought it would be a good idea to replace the fuel lines while I'm in there. anyone know what size the fuel lines are? I need to order the right size from the states.. pretty sure the parts stores here in Germany don't typically sell that stuff. any ideas for other things that i should replace while I'm at it? will most likely order gaskets, MAYBE O-rings for the injectors. Thanks! Quote Link to comment Share on other sites More sharing options...
evinX Posted September 10, 2018 Share Posted September 10, 2018 I measured my new ones when i got them, i dont have any super duper high tech micrometeres, but this is what i got. Id go with Kunifer pipe to as it dosent rust, can also be used for brake lines. German tech so id be suprised if you couldnt get it locally from performance/ brake specialists. MAINLINE FITTINGS: MALE M14X1.5 FLARED FLARE: INVERTED OUTER DIAMETER: 8MM RETURN LINE FLARE: BUBBLE OUTER DIAMETER: 8MM CANISTER LINE FLARE: BUBBLE OUTER DIAMETER: 6/7MM Quote Link to comment Share on other sites More sharing options...
rider Posted September 11, 2018 Share Posted September 11, 2018 If you need the pipe i.d. I can go measure the complete set of new fuel and brake pipes I have hanging in my garage. Quote Link to comment Share on other sites More sharing options...
evinX Posted September 11, 2018 Share Posted September 11, 2018 If you need the pipe i.d. I can go measure the complete set of new fuel and brake pipes I have hanging in my garage. It wont be accurate measuring the id due to the flares..unless you cut the piping to get the true id. Quote Link to comment Share on other sites More sharing options...
kgctim Posted September 12, 2018 Author Share Posted September 12, 2018 Thanks for the input guys! I have'nt pulled the intake manifold off yet, is it all hard lined or is there a section of rubber/fuel hose that ties it all together like most other cars?? Quote Link to comment Share on other sites More sharing options...
evinX Posted September 12, 2018 Share Posted September 12, 2018 On the main line theres a rubber section that bolts to it and goes to the fuel tank Quote Link to comment Share on other sites More sharing options...
kgctim Posted September 15, 2018 Author Share Posted September 15, 2018 Thanks, I pulled the line off today to take a look. its in great shape, so I may not replace it just yet. Quote Link to comment Share on other sites More sharing options...
