kwalker705 Posted September 4, 2018 Share Posted September 4, 2018 Rummaging through some old boxes and clearing out stuff I won't use. Custom aluminium power steering reservoir. -12AN out, -8an in. Painted gloss black. Few little Marks. But no corrosion. 2xm8 mounts on Base to mount on a bracket/plate. £40 posted to mainland UK. [ATTACH=CONFIG]229099[/ATTACH] [ATTACH=CONFIG]229100[/ATTACH] [ATTACH=CONFIG]229101[/ATTACH] SRD power steering pump feed adaptor. 90' fitting that attach's to pump to clear inlet/throttle bodies. SOLD Whifbitz black anodized power steering pump pulley. Few little marks but works just fine. £30 posted to mainland UK [ATTACH=CONFIG]229102[/ATTACH] Whifbitz black anodized aux belt tensioner pulley. Few small marks but works just fine. ( tensioner also available) £30 posted to mainland UK. [ATTACH=CONFIG]229103[/ATTACH] [ATTACH=CONFIG]229104[/ATTACH] Spec twin plate clutch hydraulic release bearing. 2 available plus 1 set of hydraulic lines and bleed nipple £60 posted to mainland uk. [ATTACH=CONFIG]229105[/ATTACH] Billet inducer wheel and exhaust wheel plus shaft from failed S366 turbo. Cannot be reused but would make some nice auto art or perhaps trophies. £45 posted to mainland uk [ATTACH=CONFIG]229106[/ATTACH] [ATTACH=CONFIG]229107[/ATTACH] Pm for more info . Will get picks added in the next day or so. Or can send pics via whatsapp if anyone can't wait till I get some uploaded. Link to comment Share on other sites More sharing options...
Silver.bullet Posted September 4, 2018 Share Posted September 4, 2018 Interested in the power steering reservoir and pulley pending pictures Link to comment Share on other sites More sharing options...
jonny mac Posted September 4, 2018 Share Posted September 4, 2018 SRD power steering pump feed adaptor. 90' fitting that attach's to pump to clear inlet/throttle bodies. £15 posted to mainland uk i'll take that dude I've got a GE pump I need to swap over to a turbo engine, would you be able to drop it off sometime if you're passing my work? Link to comment Share on other sites More sharing options...
kwalker705 Posted September 5, 2018 Author Share Posted September 5, 2018 SRD power steering pump feed adaptor. 90' fitting that attach's to pump to clear inlet/throttle bodies. £15 posted to mainland uk i'll take that dude I've got a GE pump I need to swap over to a turbo engine, would you be able to drop it off sometime if you're passing my work? No problem dude. I'll whatsapp you a pic to make sure it's the right bit. Link to comment Share on other sites More sharing options...
kwalker705 Posted September 5, 2018 Author Share Posted September 5, 2018 pics uploaded in original post for those waiting. Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted September 6, 2018 Share Posted September 6, 2018 Is the pulley and tensioner still available? Interested in it. Wii pm you Link to comment Share on other sites More sharing options...
