WeaponR 93-98 Toyota Supra Power Steering Reservoir Tank
philw99
Heyup guys, wondering if anyone had any experience with a WeaponR 93-98 Toyota Supra Power Steering Reservoir Tank?
https://frsport.com/weaponr-826-127-101-weapon-r-93-98-toyota-supra-power-steering-reservoir-tank
Think of swapping out my OEM toyota one as it was leaking on track, assume when the fluid was getting hot bits were coming out of the cap.
Also it's correct i should be ordering 4 Litres of dexron 3 right?
https://www.opieoils.co.uk/p-889-motul-dexron-iii-car-automatic-gearbox-oil-atf.aspx
Thanks
  • 2 weeks later...
The stock reservoir has sophisticated and complex anti swirl and de-aeration within it, as well as basic filtration, i doubt the alloy thing has any of that, it will almost certainly make your issues worse or even affect the functionality of the PAS. Get a decent cooler on the stock reservoir system, assuming the stock one isn't choked up inside. The cleanest way to add a PAS cooler on a manual car is fit an auto rad and use the auto box cooler in the bottom tank for PAS cooling.
