In tank fuel pump plug
mharvey
Hi all,
Just wondering if anyone knows if and where I can get one of these?
It’s the stock Toyota little two wire connector that plugs in to the top of the hanger.
Mine was rewired by a ‘professional tuner’ and it ended up not only packing up but upon taking the hanger out I discovered lumps of solder, exposed wire and connections that weren’t even staggered meaning I was lucky it didn’t short out
In addition the ‘professional wiring’ was done so close to the plug that there’s no wire left to re-do it
I am going to a Walbro 450lph pump. I’d have thought there’d be some ready made harnesses for sale but seems they all need wiring in unless someone can tell me otherwise
If anyone has a connector with wiring on it (pigtail) then that would be great
Or if anyone can supply these new? Toyota’s diagram for the hanger etc shows every other part but this connector
Thank in advance
  • 2 weeks later...
If you can unplug it and take a photo looking into the terminal ends I may be able to pick out the part number for the plug for you.
Sorry for the late reply, didn't think anyone had responded. I'll try to do that in the next couple of days. In the meantime, if anyone else see's this thread, I found a pic of the type I need
