Twin turbo 6 speed - NA speedo cluster
evinX
Hi all, question for my mate who has a TT6 engine/box/diff and has a NA manual speedo cluster. The fuel and temp work and we got the Tach working by bridging the resistor, we found that info on the forum, But were struggling to get the Speedometer to work correctly, it moves but its somewhat lagging.
Are there any tips on getting it to work? could it be the speed sensor causing the issue, different between NA and TT manual box?
cheers
the speedo should work exactly the same so sounds like either the speedo is faulty, converter/wiring or the speed sensor maybe?
if he knows the speedo was working when the tt6 stuff was in another car, then will be speedo/ converter /wiring maybe
Ok cheers Keron, ill let him know
