clarey Posted August 8, 2018 Share Posted August 8, 2018 Hi guys, did a track day the other day was great fun but being a automatic did lack a bit of speed coming out of becketts, Would it be worth putting in a manual gearbox and is it worth it and does any know the cost and where to start looking for one? Is there anything else I could do. Cheers Clare Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 8, 2018 Share Posted August 8, 2018 I would say for track work with an na yes it would be worth, unfortunately manual gearboxes seem to be becoming rarer, w58's should be available but some are from other cars so the shifter won't line up, others may have had a hard life in a higher than na powered car, all will be far more expensive than a few years back, maybe £500-£800? Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted August 8, 2018 Share Posted August 8, 2018 Another option you could look at is a wet nos kit, you can one fitted for around £1000 and run a 75 shot and that will make a huge difference coming out corners and getting power down. I fitted kit to mine and it made a world of difference Quote Link to comment Share on other sites More sharing options...
clarey Posted August 9, 2018 Author Share Posted August 9, 2018 Thank you will take a look. - - - Updated - - - Thank you will take a look. Quote Link to comment Share on other sites More sharing options...
clarey Posted August 9, 2018 Author Share Posted August 9, 2018 Thank you looking at my options. Quote Link to comment Share on other sites More sharing options...
el_bandido Posted August 9, 2018 Share Posted August 9, 2018 What's your budget? - - - Updated - - - What's your budget? Quote Link to comment Share on other sites More sharing options...
clarey Posted August 9, 2018 Author Share Posted August 9, 2018 Not sure why can it cost a lot? - - - Updated - - - Not sure why can it cost a lot? Quote Link to comment Share on other sites More sharing options...
el_bandido Posted August 9, 2018 Share Posted August 9, 2018 Depends on your gearbox choice. What are your future plans for the car? If you're planning on going turbo eventually, a W58 would be a bad choice (for example). - - - Updated - - - Depends on your gearbox choice. What are your future plans for the car? If you're planning on going turbo eventually, a W58 would be a bad choice (for example). Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 9, 2018 Share Posted August 9, 2018 Given the frankly ridiculous price of used boxes these days you're probably looking at at least 1500 quid now, maybe more for a 5 speed swap Quote Link to comment Share on other sites More sharing options...
clarey Posted August 10, 2018 Author Share Posted August 10, 2018 So I be told can’t put a turbo on a non turbo engine, would be better buying a engine with a turbo already, just going to do maybe couple more track days next year and hopefully respray her. Quote Link to comment Share on other sites More sharing options...
Darren M Posted August 10, 2018 Share Posted August 10, 2018 There’s many well documented threads on here about the na-t single turbo conversion on a ge engine. You’ve been misinformed. Quote Link to comment Share on other sites More sharing options...
el_bandido Posted August 10, 2018 Share Posted August 10, 2018 Whoever told you that was an idiot. Quote Link to comment Share on other sites More sharing options...
clarey Posted August 10, 2018 Author Share Posted August 10, 2018 Ok so I could put a turbo on then? Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted August 10, 2018 Share Posted August 10, 2018 Oh yes . I have a Na-t as do many others Quote Link to comment Share on other sites More sharing options...
David P Posted August 10, 2018 Share Posted August 10, 2018 Use Manu mode next time and change gears with the stick. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 10, 2018 Share Posted August 10, 2018 So I be told can’t put a turbo on a non turbo engine, would be better buying a engine with a turbo already, just going to do maybe couple more track days next year and hopefully respray her. Not true, but its a better, cheaper base option to get a twin turbo engine. NA/T is expensive if done properly Quote Link to comment Share on other sites More sharing options...
