Brakes overhaul and clutch master cylinder change
Tyson
I’m going to replace the both brake pipes that run to the rear brakes, front discs and pads. Also looking to swap the clutch master cylinder as it’s leaking.
I’ll be getting a garage to do this and was looking at what I should be looking to pay for each fitted.
Edited by Tyson (see edit history)
Parts cost will depend what you use and where you get it from, OE from Toyota or other supplier or ebay etc
Labour for the lot i'd have thought you'd have it done in 3-4 hrs price depends on who you use, my local
is £40 phr to me for cash :)
Oem parts Dunk for all of it.
Call Toyota Mike is the best advice i can give then go from there, i would replace the brake lines with copper
to be honest, i bought lines from Toyota and they were bent all over the shop so sent them back.
Whifbitz have prices for everything bar the brake lines to give you an idea on price
Last price i got from Toyota was £362 for discs and pads front and rear inc vat from Toyota in B'ham
Copper is the only way. Toyota discontinued them. A guy down south had some new ones for sale on here last week though.
