Cam pully o ring
mrboomberang
I have only ever seen these for sale state side. A new pulley isn’t too expensive to buy, it’s part number 13050-46010 if you are interested.
E2A
You could try these guys if you know the specs - https://simplybearings.co.uk/shop/Seals-Products-O-Ring-Seals/c19_4747_4515/index.html
Edited by Frank Bullitt
Link added. (see edit history)
  • 2 weeks later...
I now keep these in stock, e-mail me please. they now have started to leak and should be renewed when changing a cam belt or when the belt is off for other work.
I also now stock the little brake hose clips that sit BELOW the body tabs, that normally only come with new OE rubber hoses, as well as the horseshoe shaped top clips.
Sorry mate ordered them from USA missed your quote
