Intermittent Misfire
harryww89
Hi Guys,
Car has been giving me a headache this weekend with an intermittent misfire on right hand turns and vertical inputs (Bumps) under load conditions. This prevented me running at TOTB this Sunday after the issue started on the sprint track on Saturday.
I'm wondering if anybody has seen this issue before?
There is no issue with the car running on a smooth surface in a straight line on WOT, the issue is also not weather dependent from what I can gather.
To confirm;
Fuel Pressure is okay / Full tank of fuel was used on track
Coilpack clips / Coils / Sparkplugs are all new
No Boost leaks
No Blockages on inlet or exhaust side
Timing has not moved and remains set
Boost Controller and Vacuum lines are okay
I'm starting to think I have a dodgy ground or electrical connection but I'm yet to investigate.
Any ideas on what else to look out for before I start doing an 8D and IS / IS NOT would be appreciated.
Thanks
Harry
IF you didn't change the coil clips when you changed the packs and they are still original then they can disintegrate where the leads enter the clip which could allow some lateral terminal movement. Other than that I'd look to swap out the igniter with someone else in Yorkshire to see if that solves the problem. After that the cam and crank position sensors can lead to missfire occurring. Check the leads and connector integrity are good with those. Then it could be a dirty MAF sensor leading to running lean under load.
If you have a decent multi-meter you can test the sensors are functioning. I'd take a punt your problem is going to be a dodgy position sensor signal.
