Cooling system flush
Jellybean
This is for the motorcycle
What is a good method of flushing the bikes cooling system, has a build up of crap in there
Cannot find any form of flush, read a bit of water and white vinegar, bring up to temp, drain, repeat 3-4 times
Holts speed flush 250ml from Halfords
I also have the Holts 2 step rad flush (two separate bottles and you have to use one straight after the other) but didn't need to use it on my partially blocked heater matrix.
I'd go with the speed flush and see what happens as it's mild in action ie won't hurt anything and can only help as a first try.
