Smoke on idle when hot
sidewaysdan
Haha ok mate no worries it’s been a while since I’ve looked on the group.. so can you do it tomorrow then . Only joking. The car is currently SORN for the winter when would be a good time to get this upgrade done . Would the box need to come out or can it be done in?
It can be done on a lift and with a transmission jack, however, the job is far more "controllable" when done on axle stands and with an OE jack.
Doing it on a lift also means that every little spring, bolt or washer that you drop will ping off somewhere into the darkness or under the bench and a lot of the continuously dripping ATF misses the drip tray.
Doing it on axle stands, the ATF runs up your arms and off your elbows into my huge, squidgy & catches everything drip-tray, doing it on a lift the ATF runs up to your armpits and also down your neck until it drips off something else!
My spine is in a bad state and "standing-still whilst looking-up with both-arms-extended" is my nemesis and I physically can't do that anymore.
Standing-still for more than a minute traps a nerve in my lower spine, looking-upwards traps a nerve in my neck and holding both-arms-extended above chest-line traps another nerve in between my shoulders, any one of these "happenings" will floor me with "white-pain" for up to a week?
A level drive on a nice sunny day or a floor inside a workshop is as good as it gets.
Again, all of this information is in the Transmission Group, of which you are a member.
I even wrote to you by p.m. offering to upgrade your transmission to the latest Hybrid spec, free of charge, on my new level concrete drive during the lovely weather we've had all summer.
Now you know why!
  • 2 weeks later...
So bit of a update. Started the car up today and still had a little smoke . So let it warm up and took it for a quick blast to see if there was more smoke on boost and nothing no smoke at all on boost drove for a few miles came home and let it run to cool down and still no smoke... what is going on I’m so confused
Could it not be really bad valve stem seals and really thin oil mate??
Shouldn’t be the valve seals as they were done when the engine was refreshed and it’s only covered about 3k since . Suppose I could try a oil change last one was done about 500mls ago.
